displaying posts 101 to 125 of 131
Pages (6): first .. 4 [5] 6
Author Subject: Noob Supercharge Question
clen666
Post #101
Who did this for you Stan?
Team 'unintentional rat look'
Posted 4th Feb 2012 at 18:38
pugheaven
Post #102
What would most likely to go first with a standard box the diff or the gear box it's self?
So what is the average 0-60 and 0-100 with high boost and mega boost?
Posted 4th Feb 2012 at 18:40
Post #103
Miles off here...Yes
Posted 4th Feb 2012 at 18:43
atterz
Post #104
Would a 5 speed xsara box be tougher?
owain wrote:
Posted 4th Feb 2012 at 19:03
Post #105
Its hard to say, the advantage that box would have over the '6' box is it doesn't have the weak 3rd gear. Saying that though, I've had mine strenthened and given it plenty of hard miles on the track and its been fine.
Posted 4th Feb 2012 at 19:43
Post #106
Not sure on the standing start times, but in regards to what would break first in the box you would probably find either the gears would strip (especially 3rd) or the diff casing would crack. Wink
Posted 4th Feb 2012 at 19:46
marco gti6
Post #107
stan_306gti6 wrote:
I spent £860 to have the gearbox stripped, all bearings replaced, Quaiffe diff fitted (supplied to gearbox builder), all gears shotpeened and coated and all rebuilt ready to fit in car.
i suppose the 860 £ don't include the price off the quaiffe lsd right?
Posted 4th Feb 2012 at 21:51
Post #108
Thats correct, Quaiffe diff was about £550 on top of the £860 I believe. Yes
Posted 4th Feb 2012 at 21:54
marco gti6
Post #109
Thanks for the info Stan Thumbs up
Posted 4th Feb 2012 at 21:55
Post #110
No problem mate. Smile
Posted 4th Feb 2012 at 22:06
davedgti6
Post #111
No, RichW managed to break one of them too I believe, both box's about the same I think, Rich broke one by going into third instead of fifth if I remember correctly (at well over 100mph), that did a nice job of stripping the teeth off third gear, I have also done this -shit myself as the limiter immediately cut in -thought I had f*cked the engine at first Doh
Posted 4th Feb 2012 at 22:28
Post #112
I wouldn't recommend going from 5th to 3rd at over 100mph with any gearbox to be honest...LOL
Posted 4th Feb 2012 at 23:23
davedgti6
Post #113
No it was trying to go from 4th to 5th (under heavy acceleration) and went into 3rd by mistake, tis a great way to strip the teeth off your third gear LOL
Posted 4th Feb 2012 at 23:38
clen666
Post #114
Are any of the BE gearboxes stronger than the 6 box? As I've read that 3rd is particularly weak for whatever reason.
Posted 5th Feb 2012 at 09:12
Rich E Forum Admin
Post #115
To be honest, given the cost of strengthening the gearbox, and the cost of picking up a replacement, I'd just run a standard one until it breaks (which might never happen) and then think about other options if it does give up.
Posted 5th Feb 2012 at 09:21
Post #116
That's my plan
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 5th Feb 2012 at 09:27
pugheaven
Post #117
That's why I asked which would brake first, if using a standard box and an uprated diff atb or lsd, and the gears got stripped would it cause damage to the diff?
Posted 5th Feb 2012 at 10:00
Post #118
My thinking when I did this conversion was that I was spending a LOT of money building the conversion to start with and uprating all the other necessary bits and pieces, I felt it was silly to leave that bit out and make a potential weak point of the project. Wink
Posted 5th Feb 2012 at 10:05
Post #119
I planned it but ran out of funds lol, would it damage the new diff if the box said no with the quaiffe inside?
Posted 5th Feb 2012 at 10:20
Post #120
If the box started to break up inside then bits would make their way down to where the diff is and probably damage it. Yes
Depends how badly the box was damaged I suppose.
Posted 5th Feb 2012 at 10:34
Rich E Forum Admin
Post #121
So, by that logic, why did you not just get a Sadev gearbox? They quote maximum torque loadings and will guarantee their boxes will take those figures whereas with a strengthened BE box you still have no real idea about how much torque it will take. The gearbox is still a potential weak point, just to a lesser extent.
There's a magnet in the gearbox specifically to catch metal fragments in the oil Yes
Posted 5th Feb 2012 at 11:07
Post #122
because the SADEV that will take this much torque costs a rather significant amount,a BE box is rated to take mid 200's lbft as standard IIRC.
if you want a stronger standard box, ML is the one you want.
Posted 5th Feb 2012 at 12:52
Post #123
Rich,
I took this logic as Rich Walker had already carried out the conversion with no gearbox strengthening and no issues with it.
Therefore, I thought if I run the same system but add the strengthening to the equation then I would have a potentially very reliable setup. Maybe slightly over-engineered in the circumstances, but I would rather that than a large pile of broken bits! LOL
Stan.
Posted 5th Feb 2012 at 13:08
clen666
Post #124
How easy is it too fit an ML box?
Posted 5th Feb 2012 at 13:50
superchargedblack1997gti6
Post #125
I was under the impression that there are no frontwheel Sadev gearboxs on the market that will take the Torque output of Highboost. Is the one thing I have been worrying about when i go High Boost as i tend to drive my car very hard could see me destroying plenty of gearboxes. Any one point me in the right direction for a uprated gearbox?
Posted 5th Feb 2012 at 14:13
