Hi all, i bought these to fit to my 406 saloon but now i have got my gti180 205 back the 406 is surplus :-(Anyway i have fully stripped the calipers and removed all the corrosion, fitted a new fitting kit (bolts, bleed nipples etc, the only old part i refitted was the pipe that connects the two halves of the caliper together as the new ones were not bent and i made a hash of trying to shape them.
I have sprayed them with high temp base coat and laquer, i did not replace the seals as they looked in good condition, i am after £250 plus postage for them which i think is a bargain considering the time i put into refurbing them, i also have a new set of brembo discs (310mm iirc (the standard coupe disc) if you want these too then it will be £300 plus postage or you are welcome to collect, i am in ilkeston, derbyshire, sorry i cant do clickeys but here is a link to photobucket where there are loads of pics
http://s159.photobucket.com/albums/t157/jubby1/brembo%20calipers/
205 mi16405 Mi16x4 restoration project
406 v6 saloon track car project/daily driver
508 Hdi
