Author Subject: mocal oilcooler/sandwishplate
nadium
hey guys was thinkin how do i mount the sandwish plate to the engien, got a set from mocal but i can not see how i can mount it. pics ftw maybe thank you
Posted 3rd Jan 2012 at 11:55
My sandwich plate sits between the oil filter and the heat exchanger. I'm sure there are a couple of guides on here on fitting them.
There are probably a few pictures of mine somewhere in my track car build, link in my sig. Smile
Posted 3rd Jan 2012 at 12:06
remove oil filter, fit sandwich plate, re-fit oil filter.
simples Smile
best way is to keep the heat exchanger, might need a short filter though.
Posted 3rd Jan 2012 at 12:08
nadium
ye but the screw that comes with mocal is a short one ? i looked engien projects but could¨nt find a good pic of it
Posted 3rd Jan 2012 at 12:19
nadium
aaarrh jost fit on to the stock oilfilterkonsol?
Posted 3rd Jan 2012 at 12:20
if it'll fit.
that's how all the saxo+c2 works rally cars are done, means the oil warms up nice and quick, but when the oilstat opens the oil will cool sufficiently Smile
Posted 3rd Jan 2012 at 12:42
I'm on my pc now so have had a search for a few photos, can't find any great ones but here are a couple of mine:
I've never had any clearance issues with the normal filter supplied by Peugeot/AEP direct.
Posted 3rd Jan 2012 at 17:48
is that with both fitted? not 100% clear
edit, just spotted the water pipes LOL
awesome, might do that next time I faff with my engine Smile
Posted 3rd Jan 2012 at 18:01
Yes
Posted 3rd Jan 2012 at 18:02
You need an extension nut to be able to fit both the heat exchanger and the sandwich plate....you fit the extension nut onto the nut that is already holding the heat exchanger on, and then the oil filter screws onto the extension piece after the sandwich plate.
Posted 3rd Jan 2012 at 20:34
nadium
but the extension nut i think that comes with the mocal kit ??
Posted 3rd Jan 2012 at 21:08
fatlapit
why keep the heat exchanger???
Posted 3rd Jan 2012 at 21:29
to warm the oil up quicker, cold oil is just as bad as very hot oil.
Posted 3rd Jan 2012 at 22:20
The heat exchanger helps heat the oil up from cold, which is a good thing.
The mocal extension tube nut thing came with both my oil cooler kits, I'm not 100% sure but i think its the M20x2.0 version. It's worth double checking that before ordering.
Posted 3rd Jan 2012 at 22:21
its 20x1.5 Smile
Posted 3rd Jan 2012 at 22:30
jeffers Forum Admin
I thought it was m18 but either way if u tell them the car it's for beforehand when ordering they send the right one.... At least that's what I did..... Dunno
Team Running Engine again!
Team Negative Camber!
Posted 3rd Jan 2012 at 22:37
fatlapit
u not running a thermostat in the sandwich plate
Posted 4th Jan 2012 at 17:59
I am, otherwise it would take ages for the oil to get upto normal temperature, which is bad for the engine.
During the cold months i put a blanking plate over the front of my oil radiator to stop air going through it, even though my sandwich plate has a thermostat it still allows a little bit of oil to go through the radiator circuit meaning it takes longer to warm up the oil.
Posted 4th Jan 2012 at 18:49
