Author Subject: Painting inlet manifold
Gti6rooty
unsure what section to post this in
in the stage of tidying up of the engine bay and the inlet manifold is looking a bit tatty,
would painting this normally be ok, or due to the heat would it flake,
Snap off,because it's french
Posted 28th Dec 2011 at 15:00
chris with a pug
If you fit a PTFE gasket it keeps the temp down even more, but using normal paint should be ok. Making sure the surface is uber clean and a good etch primer is more important. I would use a petrol resistant lacquer just in case though.
Posted 28th Dec 2011 at 15:03
gman
Initially I prepped mine properly and primered, painted and lacquered with Halfords stuff. Within 6 months it started to flake.
I had another manifold lying about, so I gave it a quick degrease, and sprayed with normal silver Hammerite and 6 months later it still looks great.
So in short, just use hammerite Thumbs up
1992 Onyx Black 205 GTI-6
2005 Honda S2000 (Sold)
2002 Audi S3 (Sold)
2005 Clio 182 Trophy (sold)
Posted 28th Dec 2011 at 15:10
antcla.85
Heat was a big issue with mine, used etch primer and it still discoloured, none was white tho. Has gone yellow.
Life is short, make it interesting
Buy a Peugeot!
Posted 28th Dec 2011 at 16:05
judge dead
theres loads of hi-temp primers/paint on ebay for 5-10 quid if you wanted to be on safe side of things just look for exhaust paint itl be highest temp ones you can get i think.
Posted 28th Dec 2011 at 16:19
Powdercoat. I got mine bead blasted and powder coated for £40. By the time you've bought a few tins of brake cleaner an degreaser to get it squeeky clean, a few tins of paint and an afternoon - your better off letting someone the the whole lot and have a harder wearing finish.
  • Posted 28th Dec 2011 at 18:01
    oecken
    Makes a world of difference, do it! on the old 6:
    To this:
    Posted 13th May 2013 at 08:29
    Fred revival.
    Posted 13th May 2013 at 08:39
