Author Subject: oil catch can
sonicste
any body fitted a oil catch can to a phase 1 just a little unsure what pipes go where if you know what i mean
sonicste
Posted 27th Dec 2011 at 20:49
yes i have,HTH
Posted 27th Dec 2011 at 20:57
sonicste
little bit of help then pls
sonicste
Posted 27th Dec 2011 at 20:59
rickyk
Not sure how it works on a '6, but generally the pipe that goes to the inlet should instead go to a catch tank. The hole on the inlet should be blocked.
I could be wrong though.
Posted 27th Dec 2011 at 21:10
judge dead
if you look up cwpellowe project thread "sundance 2.0" im sure hes got a picture of his ive seen it on his car but cant rember if hes got any photos off it im sure he will tho his is a ph1 with ph3 front end ect
Posted 27th Dec 2011 at 21:15
24seven
The pipe going to the inlet has a catch can fitted between the inlet and wherever it comes from. You can't just put a can on the end of it and block off the inlet, as you still need the breather system working. A catch can just catches the heavier oil vapours instead of feeding them back through the engine.
Posted 27th Dec 2011 at 21:16
rickyk
I prefer to go from the catch tank to a breather filter rather than back into the inlet.
Posted 27th Dec 2011 at 21:20
24seven
It depends on the engines. Some depend on the vacuum from the inlet to aid the breather system, and with a catch tank there you'll not be drawing in any oil vapours any more, so save upsetting the balance of things I'd keep it as stock as possible. I know most road-based race engines keep a feed to the inlet because at high RPM the vacuum aids the breather system. The engine in our Formula Renault is like this and we were advised not to change it.
Posted 27th Dec 2011 at 22:25
rickyk
True, i've only got an old diesel anyway!
Posted 27th Dec 2011 at 22:29
mabgti
NV motors
This is what a subscription does... Frikkin delete any engine threads in the general section. Rant over
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 28th Dec 2011 at 00:56
24seven
... because catch tanks and breather systems are exclusive to the '6/rallye... Roll eyes
Posted 28th Dec 2011 at 00:58
