Author Subject: C5 wheels rubbing on gti6 calipers
rallyeash
just fitted my new C5 alloy steel's on my 205 along with new Gti6 calipers, Mintex 1155 pads, braided lines, new discs etc and the top of the caliper just slightly rubs on the inner topside of the rim. its only fairly slightly and there isnt much resistance but took the wheel back off and can see the marks on the caliper and inside of the rim. i think once the pads have worn down a bit will move the caliper away from where its rubbing.
Anyone else had any issues when fitting C5's?
ps these are on 205 1.9 hubs but im sure the offset is exactly the same...
309 3dr K20 Type R
Posted 27th Dec 2011 at 13:22
Give you a tenner for the wheels then, obviously faulty Whistle
Posted 27th Dec 2011 at 13:38
matt evans
Mine are very close but no rubbing
honestly3k wrote:
owain wrote:
Posted 27th Dec 2011 at 15:41
rallyeash
have taken it out for a drive properly now and covered about 25 miles, has stopped the slight rubbing. no damage on either rim or caliper so should be fine. Smile
309 3dr K20 Type R
Posted 27th Dec 2011 at 16:17
matty_rallye
Doesn't sound like there will be much hope for my hispecs then Sad
2.1 16v 306 Rallye.
Posted 27th Dec 2011 at 16:52
rallyeash
should be ok with your spacers
309 3dr K20 Type R
Posted 27th Dec 2011 at 17:06
no problems with mine at all, did you have stick on weights on the inside?
Posted 27th Dec 2011 at 19:09
rallyeash
they were knock on weights.
it was the part where the inner rim is joined to the outer section.
309 3dr K20 Type R
Posted 28th Dec 2011 at 12:19
beez_neez_gt
How would the pads being worn down make any difference ?
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 31st Dec 2011 at 00:25
tvrfan007
Carrier stays put but the caliper moves inboard with pad wear, as the piston extends.
I'm Si btw Tee hee
Night Blue VW Golf GTD
Posted 1st Jan 2012 at 21:53
I've had mine on with brand new o.e pads and they didn't rub Smile
Posted 1st Jan 2012 at 22:02
