| Author | Subject: GETTING THERE Fatlapits turbo (turbo frog) |
fatlapit
Location: STOCKSFIELD Registered: 02 Nov 2010 Posts: 3,040 Status: Offline |
Post #401
watching swifty etc at xmas stages i need one lol________________________________________ |
marco gti6
Seasoned Pro Location: Troisvierges Registered: 09 Mar 2009 Posts: 1,350 Status: Offline |
Post #402
Awesome build you did |
fatlapit
Post #403
yes mate cheers bud ________________________________________ |
pug_306
Seasoned Pro Location: Great Hockham Registered: 28 May 2013 Posts: 1,597 Status: Offline |
Post #404
This is one of the best looking 306s ive seen :-) Good work________________________________________ 1998 Supercharged White Rallye1992 205 GTi6 205 Turbo 340bhp |
fatlapit
Post #405
cheers mate thankyoushe will be at fcs ________________________________________ |
fatlapit
Post #406
marco gti6
Post #407
What is the setup of your rear beam then? How much chamber an drop if you dont mind me askingCheers |
fatlapit
Post #408
http://www.306gti6.com/forum/showthread.php?id=128368 read this mate page 1 ________________________________________ |
fatlapit
Post #409
23mm torsion bar's painted red.30mm anti roll bar. crf450 negative camber trailing arms. I also had threads put in the stub pins just in case I went to rear coil overs at some time. rebuilt with new wheel bearings. Beam tube painted yellow. All genuine Peugeot beam rebuild parts. It also has One of a kind PhillipM flower petal discs. Standard callipers painted black. BBM solid mounts. ________________________________________ |
craig903
Regular Location: whitstable Registered: 08 Jul 2013 Posts: 273 Status: Offline |
Post #410
The radiator your using fatlapit does it still sit on the crossmember or have you had to drop it behind the crossmember?________________________________________ 208 GTI OwnerTurbo'd '6 project - work in progress |
fatlapit
Post #411
Sits on the crossmember in the same place. But with new holes drilled________________________________________ |
craig903
Post #412
Do you have a link to the radiator you have or the sizes etc? I've got a rad but it sits too tall. It looks ever so similar to the one you have. the filler hits on the bonnet on mine.________________________________________ 208 GTI OwnerTurbo'd '6 project - work in progress |
pugheaven
Seasoned Pro Location: Fareham Registered: 17 Dec 2006 Posts: 4,602 Status: Offline |
Post #413
Pro alloy ftw |
craig903
Post #414
pugheaven wrote: Pro alloy ftw ![]() After seeing your's I was considering it because it looks awsome, sadly, £1500 is too much for me. ________________________________________ 208 GTI OwnerTurbo'd '6 project - work in progress |
fatlapit
Post #415
Aye its good but i was going custom. Id only go to spec r________________________________________ |
fatlapit
Post #416
Theres nowt wrong with my set up if anything its over cool________________________________________ |
fatlapit
Post #417
CORE SIZE: 360H * 648W * 52T OVERALL SIZE: 668W * 446H * 64TT INLET/OUTLET: 35/35 MM ROW:2 ROW ________________________________________ |
craig903
Post #418
Ok mine is 50mm taller then your's________________________________________ 208 GTI OwnerTurbo'd '6 project - work in progress |
pugheaven
Post #419
I'm trying to get a price for just the rad and cooler with out boost pipes, fans or powdercoating which should bring the price down!They way I see it is if you have a fast car you want good brakes and suspension, if your running serious power you want the cooling system to be good too if not your are just compromising the engine |
fatlapit
Post #420
Mine took 9 litres lol________________________________________ |
craig903
Post #421
whats the clearance like from the rad cap to your bonnet?________________________________________ 208 GTI OwnerTurbo'd '6 project - work in progress |
fatlapit
Post #422
There is a fair bit.If my set up didnt work i was gonna go down the custom road. But tbh an evo intercooler and a s14 rad are already designed for hot turbo cars. ________________________________________ |
fatlapit
Post #423
Must be 3" i would say________________________________________ |
straki007
Newbie Location: Chomutov Registered: 26 Mar 2015 Posts: 2 Status: Offline |
Post #424
Nice work... |
fatlapit
Post #425
Cheers bud________________________________________ |
