where does it usually come from and how can it be stopped? It's a sunroof model.
| Author | Subject: Rains getting in! |
Batesy86
Regular Location: Canterbury Registered: 12 Dec 2011 Posts: 138 Status: Offline |
After the heavy rain, I've found damp patches on the roof lining at the top of the b pillar. Also the os rear footwell is damp where does it usually come from and how can it be stopped? It's a sunroof model. |
Park it in a garage. ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
Also check your gutters for the sunroof arent blokes________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
blocked________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
atterz
Seasoned Pro Location: Stafford Registered: 18 Feb 2011 Posts: 1,134 Status: Offline |
Gutters in sunroof, my DT does it after sitting under a tree for 9 months! Get a long piece of stiff wire and poke it through. Then test with a cup of water. Best to sort it quick or risk a rotten roof!________________________________________ owain wrote: A GTI-6 with a good dashboard and the seats down can outsprint an E46 M3 in July. |
sixygti2
Seasoned Pro Location: Tunbridge Wells Registered: 21 Apr 2007 Posts: 2,778 Status: Offline |
HereNot sure how you stop it though, sorry ________________________________________ Still watching you... |
Batesy86
How do you get to these gutters? Won't have a garage to keep it in until late January! |
also check door seals for any small tears/rips in them |
atterz
open the sunroof and in the front corners you will see the gutters/expelling water thingy majigs (this name confirmed on servicebox), these are the things you must clean out, and the lead to just behind the front wings.________________________________________ owain wrote: A GTI-6 with a good dashboard and the seats down can outsprint an E46 M3 in July. |
Batesy86
I'll arm myself with a metal coat hanger and take a peek this afternoon |
mechanical_repairs
Also re seal the aerial base, very common.Carl ________________________________________ C.G.Cars of Leicester, Peugeot/Citroen/Renault specialist Tel: 01162 624498/07799 405184 WWW.CGCARSLEICESTER.CO.UK36 narborough road south, Leicester LE3 2fn MOT station now open, tests £35 with a free retest. Recovery available with a recovery unit, for those not so local jobs Also offer the loan of a free courtesy car 306 dturbo |
Forgot about the ariel, I had to seal mine. ________________________________________ andrew315rawson@live.co.ukMoonstone phase 7 gti6 My Project thread: http://www.306gti6.com/forum/showthread.php?id=119992&page=1 |
Batesy86
mechanical_repairs wrote: Also re seal the aerial base, very common. Carl Would this cause the rear well behind the drivers seat the get wet though? Just been outside, my coat hanger wouldn't go down the holes, presumably its to thick and doesn't have enough give to turn corners. I poured 1/2 pint of water down each one though and water was exiting under the car at a decent rate. Did find a small tear in the door seal though, I can;t see how it would explain a very damp carpet at the back though...The seal doesn't look like it fits well, it seems an inch too short so isn't tight around the whole door, one place will always be lifting away. Here's a pic of the tear. |
Batesy86
Here's a pic of the seal coming away. It wants to come away at some point no matter where! |
with a tear like that it wont be helping at all, find a replacement ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jimmyhackers
Seasoned Pro Location: birmingham Registered: 14 Jun 2011 Posts: 1,302 Status: Offline |
like has been said before. its either your aerial seal or sunroof seal. check their condition and replace if needed. i cleaned then greased up my seals on my 1.4 roof, that helped and was free/easy to dothat door seal tear may be letting in some water. but i wouldnt think enough to get to the roof. are the carpets wet around the bottom of the door seal? if so it may need replacing i know you said this happened after heavy rain so its more that likely the seals but the other possibility is your rear washer line is leaking? i think it runs on that side. have you been using your rear washer jet? does the water inside smell or have any discolour to it? has your washer bottle been emptying quickly? good luck with fixing it ________________________________________ the world is changed by people in sheds |
mcfc1987
Seasoned Pro Location: lincoln Registered: 13 May 2008 Posts: 1,478 Status: Offline |
leaks normally stop if you pay your £5 membership ________________________________________ |
atterz
Tryed that and the DT sunroof still leaks .________________________________________ owain wrote: A GTI-6 with a good dashboard and the seats down can outsprint an E46 M3 in July. |
Batesy86
mcfc1987 wrote: leaks normally stop if you pay your £5 membership Lol! Maybe after xmas! I'll have to check the sunroof seal then as the drains are working. Can you still get seals at such from Peugeot? |
seans6
Senior User Location: Cheshire Registered: 11 May 2011 Posts: 530 Status: Offline |
I used vasaline on my old spaxo sunroof when it leaked, was a temp fix before i got a new seal and worked a treat! Just make sure no ones looking when your rubbing vasaline into the roof |
pugzy
Seasoned Pro Location: Forest of Dean Registered: 11 Jan 2005 Posts: 5,543 Status: Offline |
Exactly same happened on my 106 mate...Pulled back the roof lining above the drivers side to see the underside of the sunroof corner - it was totally rusted and where the drain pipes beginning at the sunroof and ending up down towards the drivers foot well was blocked. The water gathered in the corner of the sunroof, rusted and rotted through the bodywork, straight onto the lining. This soaked the lining and down the A-pillar, into the footwells on the drivers front and rear sides. £60 later at the bodyshop where it was resealed and rebuilt and I've had no problems since ________________________________________ Pugzy...aka MikeEx-Platinum silver 306 GTi6 owner...now an Ex-Scarlet Red 406 3ltr V6 Coupe owner too ![]() Now driving a China Blue 106 1.5 Diesel..."The Money-Saving and Debt-Busting Machine" |
mark.evs
Senior User Location: Near Bridgend Registered: 21 Dec 2010 Posts: 527 Status: Offline |
That damp patch will be where the rubber pipe meets the metal work of the sunroof, get under the roof linging and stick a jubile clip on it. I done it on my old dt too. ________________________________________ My GTi6 track projectWhite Rallye project |
Batesy86
IS there an easy way of getting under other than taking off the a/b/c pillar trims off? |
