Author Subject: S16 drive shaft
tarret
Im lookin for an s16 passenger drive shaft as I've got an xsi one from brackers and is completely different,
Don't know if a gti6 shaft will fit but don't wana take the chance,
Can anyone help Smile
Posted 17th Dec 2011 at 14:02
i bought gti shafts off jonnie205 on here and they went on my s16 engine without problem
Posted 17th Dec 2011 at 14:08
ryangti6
S16 are the same as Gti6, maybe xsi one came off a car with no Abs otherwise they should be the same too.
Ryan
Posted 17th Dec 2011 at 14:23
mr swampy s16
**BAD SELLER**
make sure the number of teeth on the abs sensor ring are the same
when i needed a new one i had the choice of two
Posted 17th Dec 2011 at 14:53
I've got a gti driveshaft here
  • Posted 17th Dec 2011 at 18:31
    miles
    Should have some but drop me a email on contact@pugracing.com or I will forget to have a look, But the only differance is the ABS ring, the later 6 shafts etc are a hollow tube instead is a solid shaft
    www.pugracing.com
    Posted 17th Dec 2011 at 22:42
    tarret
    The xsi one had the abs ring,
    its either 28t or 49t I think
    Mine is 28t so was the xsi but the shaft was fatter an slightly longer,
    I've manger to get one and car is now runnin but it has play in the knuckle joint and knocks/vibrates over 4500rpm so I'll have to get another one soon as.
    Posted 17th Dec 2011 at 22:55
    davidmartin
    Got a new one here part no 3272 0G ,Trouble is they changed part numbers in January 96 ,so don't know if it would be any good to you.
    This is what it says on service box
    INJECTION XU10J4 AND BVM BE3 SINCE RPO No. 07000 OR INJECTION XU10J4RS AND BVM BE3 SINCE RPO No. 07000 OR TURBO DIESEL XUD9TE AND BVM BE3 SINCE RPO No. 07000
    pet hate, the cat
    Posted 17th Dec 2011 at 23:56
    tarret
    Is there any chance you Could send a picture of it?
    Is it abs shaft if so how many teeth has the abs ring got?
    Posted 18th Dec 2011 at 19:10
    davidmartin
    29 teeth on the ring .
    pet hate, the cat
    Posted 18th Dec 2011 at 19:50
    tarret
    Mine has the soild shaft that is the hollow one, im thinking they should still fit,
    How much was you looking for it?
    Posted 19th Dec 2011 at 00:43
    davidmartin
    £45 plus the postage, The Q-drive ones in eurocarparts are 108 quid plus 72 pounds surcharge so it's a damn good price.
    pet hate, the cat
    Posted 19th Dec 2011 at 05:55
    tarret
    That sounds great, I'll take it but is there any chance you could hold it till after Christmas?
    Dean
    Posted 19th Dec 2011 at 10:13
    davidmartin
    No problem,don't need to sell it.Just clearing the basement out .got no room to work down there at the momentLOL
    just let me know when you want it.or if you change your mind.
    pet hate, the cat
    Posted 19th Dec 2011 at 15:10
    tarret
    Ill defo take it ill let just after xmas, Thank you
    Posted 19th Dec 2011 at 18:29
