Author Subject: 2148cc bottom end
vxedcc Banned!
At present I am only testing the water on this sale, but ideally it needs to go as it's sat doing nowt...
Bottom End with all new parts used
New big end bearings
Cast Iron Block re-bored to 88mm
Forged 88mm Pistons
Lightened and balanced 88mm Crank.
Lightend and balanced flywheel
Trap door sump baffle
I have a folder full of the receipts for the engine build.
I spent a lot of money on a complete engine package which worked fine for 3-4 weeks, but after about 750 miles I noticed pressurised water and dumped the oil, to find a very milky bottom end. We then assumed the head gasket had failed, spent £230 getting headwork sorted, £100 for a new 88mm gasket and a further £200 on bits and bobs... Started her up and she ran fine. However a few weeks later and the same issues has shown their selves... same cylinder.
After speaking at length with Sandy he has suggested its possible the bottom end has suffered from porosity (its broke). When Sandy had a look at the map (as took a standard GTI6 to him on old ECU) he said (without being rude) it was not the 'best' of maps.
Although there is a possibility that nothing is wrong with the bottom end and it may be an undetected fault elsewhere, I am selling this as in need of a new rebored block. You can simply transfer over all the bits inc bearings from one block to another.
I will take all genuine interest seriously, but as it stands I wont split bits and bobs. I can also include 467cc injectors which have been serviced and cleaned twice.
I have paperwork to back up everything if you have any doubt, any questions please just ask.
Also, this engine along with a set of mild cams and mi16 head made 218bhp but 174ftlb
Posted 15th Dec 2011 at 00:35
devere
I know you said your not splitting, but if you do, is there any chance of a picture of the sump?
Posted 15th Dec 2011 at 08:17
price would be good dan LOL:
Posted 15th Dec 2011 at 09:20
soton_s16
I could be interested, but depends on price...
For all your Peugeot needs PugRacing.com
Gti S16 199bhp 164 ft lbs torques!
Posted 15th Dec 2011 at 09:37
vxedcc Banned!
Im sorry I forgot my password to login via work today so had to wait until I returned home.
Just the bottom end with everything as it is, I would like to see about £575.
For £625 ill include a Cometic Headgasket which has seen 5 minutes used. still currently fitted as engine is still complete unit.
I hope this doesnt sound stupid, but the entire package I bought owed me £3200. Im sure you'll appreciate that the bottom end needs a new block, which can be had for free pretty easily and then its the price on a rebore (circa £120).
I am stripping the engine into bits to sell so if you wanted to buy the head and exhaust as a package i can send more info on them too, I would look for £1250 as a complete engine package.
Couple of pictures
Posted 15th Dec 2011 at 19:40
clen666
Interested in crank if you end up splitting the whole lot
Team 'unintentional rat look'
Posted 15th Dec 2011 at 19:43
pete_rallye
About the porosity, were the cylinders checked for cracks when the head was off? Just I've had 2 blocks bored to 87mm now and they have both cracked, one for no apparent reason, (the other because a valve head bounced about)... Not sure if thats common or not but might be worth checking....
Lap of the 'ring
Posted 15th Dec 2011 at 19:47
vxedcc Banned!
It was something which we didnt look at (evidently) in enough detail, litterally a glance to see if we could see a hole!
Posted 15th Dec 2011 at 19:49
vxedcc Banned!
I have been told this is a bit over the price of where it should be. Also, due to personal injury could do with this being taken out of the way asap.
So as a revised price, this is now £400.
That will be for the new bearings, 88mm crank, rods and 88mm pistons. Treat the block as scrap, but it can go with the crank and pistons intact if required.
Posted 19th Dec 2011 at 15:43
