Author Subject: Timing belt
colgti6
How can u tell if a timing belt is to tight?
Adding up the bills for the 6
Posted 11th Dec 2011 at 14:18
It will snap
Makes a Nasty squealing noise ?
Posted 11th Dec 2011 at 14:37
colgti6
Mine don't squeal it just whines I thought it was because it was to tight
Posted 11th Dec 2011 at 14:44
jeffers Forum Admin
It makes a wining noise when the engine running. Take the belt cover off and twist the belt between thumb and forefinger on the longest un supported side of the belt, if u can twist the belt more than 90 degrees it too loose, if u can't twist it 90 degrees it too tight. Hth.
Team Running Engine again!
Team Negative Camber!
Posted 11th Dec 2011 at 14:48
ablister
has timing belt just been done?
306 rallye, Richard Longman engine
rc10gt
Posted 11th Dec 2011 at 15:55
monkeyman
Turn engine off before removing belt cover and checking tension
Forum Search Clicky
Posted 12th Dec 2011 at 20:08
