Author Subject: Shaking from my rear
speedo306
Hi can anyone help me out with this? When driving over any rough surfaces I am hearing a sort of jiggling coming from the back of my car in the area of the rear suspension. I recently did over my rear suspension and changed the pins and bearings. This is wrecking my nerves. Help!!PleaseCrazy
RJ
Posted 10th Dec 2011 at 21:06
matt evans
Initially i'd look at the rear beam mountings, both front and rear. Are you sure its suspension noise and not something else? Could be the spare wheel , exhaust, check the obvious before ripping it apart.
When you "did over" the rear suspension what exactly did you do?
honestly3k wrote:
owain wrote:
Posted 10th Dec 2011 at 21:25
jeffers Forum Admin
I had this after rebuilding my rear beam, check the top damper bolt is tight as they can cause a right racket! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 11th Dec 2011 at 14:43
I had a clicking noise from my rear beam last year, it was the little bolt that holds the ARB end plates which wasnt quite tight enough, allowing the plate to slip when the arms moved up and down.
Posted 16th Dec 2011 at 18:09
judge dead
i have a loud bang every blue moon from my rear axle ive just kept driving more i drive less it appears Smile
Posted 16th Dec 2011 at 18:15
