Team Diesel
| Author | Subject: Trailing arm shaft depth |
cornish_pug
Regular Location: Marazion Registered: 18 Dec 2009 Posts: 368 Status: Offline |
How far should the trailing arm shafts be pressed into the trailing arm.________________________________________ Team Diesel |
jord294
you still doing this? i tend to leave approx 1-2mm so the foam ring on the arb end plate has somewhere to sit in ________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
recessed 2mm from the outer face, pug specified this.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
cornish_pug
jord294 wrote: you still doing this? i tend to leave approx 1-2mm so the foam ring on the arb end plate has somewhere to sit in Unfortunately yes! Only been able to do bits here and there, been busy with work. Cheers for the info guys! ________________________________________ Team Diesel |
