Author Subject: No oil pressure!
thewho07
As title says. I am getting no oil pressure whatsoever. Aswell as the pump, what else can i check?
Posted 26th Nov 2011 at 18:08
crank pulley bolt, oil filter, sump plug...
Posted 26th Nov 2011 at 18:26
thewho07
New oil filter and sump plug washer just fitted. Could there possibly be a leak?
Posted 26th Nov 2011 at 18:27
How do you know you have no pressure ?
Posted 26th Nov 2011 at 18:33
thewho07
It has been tested today
Posted 26th Nov 2011 at 18:34
Tested by ? And with ?
Pump prob shagged or chain busted bit odd though
Posted 26th Nov 2011 at 18:37
thewho07
Tested by mechanic at local garage with an oil pressure tester. He didnt have time to investigate further today, so just trying to see what it could be before going back into the garage on monday! Yeh it is odd. Timing belt has just been done too. Timed up spot on, but no oil pressure! I've just changed the sump plug washer and oil filter the other day, what could I have done wrong? Done it plenty of other times without any problems.
Posted 26th Nov 2011 at 18:43
what filter was it?
Posted 26th Nov 2011 at 18:53
thewho07
what filter was it?
Motaquip, from GSF parts.
Posted 26th Nov 2011 at 18:56
Hmm
time to drop the sump then
Posted 26th Nov 2011 at 19:28
rich_w
What phase car is it?
If it's a Phase 1 or a Phase 2, you could have the interference type oil pump drive, which isn't positively located via a keyway on the crankshaft.
It is just driven by the clamp load from the crankshaft pulley bolt.
If your timing belt has been recently changed, and this problem has just developed, to me it sounds suspicous. I would check the toque on the crankshaft pulley bolt - if this isn't tight enough, your oil pumo won't be getting any drive.
Contact Details:
07732 822546
Posted 28th Nov 2011 at 13:41
allanallen
Do you mean no or low oil pressure?? I take it you havent started the car and are checking it by turning it over?
Facebook
Posted 28th Nov 2011 at 14:41
thewho07
Its a phase 3. There is no oil pressure whatsoever. Just waiting for my mechanic to have a look at it hopfully in the next few days. The torque on all the bolts was done by the book though, so should be spot on! Getting worried now! Unsure
Posted 28th Nov 2011 at 16:01
are you driving it about?
did he remember the big washer under the crank pulley bolt?
Posted 28th Nov 2011 at 17:01
thewho07
Just been to pick it up! Its sorted. Somehow, the crank pulley was not sitting on the crank right
Posted 28th Nov 2011 at 17:13
allanallen
Awaits op's next topic 'loud knocking noise when accelerating'
Facebook
Posted 28th Nov 2011 at 17:23
thewho07
LOL
Posted 28th Nov 2011 at 17:30
jord294
and the name of your mechanic is.....
Posted 28th Nov 2011 at 17:42
thewho07
Haha. People make mistakes! He knew it had to be somthing he had done, just didnt know what! Got it all for free atleast
Posted 28th Nov 2011 at 17:45
