Author Subject: creaking from front (not top mounts)
lewisdmz
I've got an annoying creak which sounds like it;s coming from the offside front, it happens when gently coming off the accelerator pedal and also when turning from lock to lock(stationary and slow speeds). Some times it's just one very quiet knock and other's it's more like 3 little creaks. Sometime's it will also do it when i'm travelling along very slowly ~2mph.
Does not happen at high speeds or when travelling over uneven ground.
The annoying thing is the car has recently had:
- top mounts and dampers
- complete wishbones
- rose jointed droplinks
All the wishbone bolts are tight, arb clip things look to be seated correctly. No play in the wheels at all if i grab them at 12 and 6 or 3 and 9 oclock. If you jack the car up then turn the wheel it doesn't do it.
I'm pretty stumped? TRE?
Posted 26th Nov 2011 at 14:20
gti6power
could be top engine mount because my car does the same
Posted 26th Nov 2011 at 14:58
darzmat
i would say you've got two problems, as above i would say the creak is the top engine mount (search for chassis repair, unless you have already read it)
dont know aht the knocks will be when turning and traveling at slow speeds
Posted 26th Nov 2011 at 16:34
lewisdmz
If it was the top engine mount I would expect it too clunk every time I brake or accelerate though, it's only slow speeds, there's no clunk on gear change etc when hammering it.
Posted 26th Nov 2011 at 18:02
Droplinks or loose electric ckips
Posted 26th Nov 2011 at 22:32
If the balljoint pinchbolts have been over tightened they can stretch the holes they go into and cause some movement/creaking. Or as said you may have more than one issue. But I'd nut and bolt check the entire front end, should'nt take that long really.
Posted 28th Nov 2011 at 09:48
I agree with Jim, with torque wrench I must add!
The BJ holes dont tend to go on the 18mm hubs, unless some right gorilla has been at them, the earlier 16mm arent as resilient.
Tend to notice it in wayward steering over ruts+power/torque shifts (i.e lift off or boot it) didn't have any creaking however.
Posted 28th Nov 2011 at 10:50
lewisdmz
Hmm, the hubs are 16mm.
At one point I did think the car was a bit twitchy when going over ruts e.g. crossing the center of the road. But after going out at the weekend the handling is fantastic, very sure footed. I think the earlier worries were just caused by really bad roads.
cheers anyway, think I might need to start researching rack related noises...
Posted 28th Nov 2011 at 22:18
