Can you buy them from Peugeot?
Thanks
Team Diesel
| Author | Subject: Rear beam tube end (bearing housing) O/S |
cornish_pug
Regular Location: Marazion Registered: 18 Dec 2009 Posts: 368 Status: Offline |
Does anybody have a good rear beam tube end for holding the outer bearing.Can you buy them from Peugeot? Thanks ________________________________________ Team Diesel |
jord294
There is no end. You need another tube________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
jord294
I'm pretty sure it would of been cheaper to buy a re-furbed one from me in the first place________________________________________ FRESHLY RE-FURBISHED GTI BEAMSFITTING AND LOWERING AVAILABLE. ALL AXLES BUILT USING GENUINE PEUGEOT PARTS IF I'M NOT HERE, IT ONLY MEANS ONE THING.... I'M SOMEWHERE ELSE! |
![]() you need another crossmember, get down't scrappy and strip a few apart see if they have a good one. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
cornish_pug
The tube end was worn but not majorly. I managed to pack the the worn side with some decent shim.________________________________________ Team Diesel |
Rich E
Eesh. I'll give you about 2000 miles before you're taking it apart again then.________________________________________ Rich |
I would have at least built it back up with a decent weld and turn it back down.________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
