displaying posts 101 to 125 of 130
Pages (6): first .. 4 [5] 6
Author Subject: spoilt brat needs opinon on engine modifications
aaron6
Post #101
This os true. Although he should have got rat boys engone and dump it in. well, thats what I'd have done.
Posted 3rd Dec 2011 at 09:09
Post #102
we all make mistakes I suppose, its how we learn.
It's when we don't learn from them we have to worry!!
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 3rd Dec 2011 at 09:46
Post #103
Agreed, I almost wish I had grabbed it myself as a good spare.
Posted 3rd Dec 2011 at 17:16
darzmat
Post #104
jimmyhackers wrote:
i was told it was capped at 7000 in the phase 2
my ph2 revs to either 7250 or 7450, not driven it in a couple of months though so cant remember lol
Posted 3rd Dec 2011 at 20:38
jimmyhackers
Post #105
im giving up on spending on the engine for now. its not worth the money for a rebuild after ive been cleaned out as it were. new lighter seats, bonnet and windows with a few other mods will make the car exactly what i wanted it to be from the start. a goodlooking reliable light hot hatch that handles well
plus all these things can be easily transfered to a new car. the same way if i get an oil intercooler and an electric water pump. they too can easily be transfered to a new engine. things like uprated cams con rods or a full sc conversion is a little more time consuming.
Posted 4th Dec 2011 at 01:36
Post #106
Phew, that's a relief Yes
Sounds like a much more sensible idea, exactly what I did with mine. The shell is a beaten up P1 shell, so I've been reluctant to do anything that couldn't be moved to another shell. Suspension, Lexan windows, oil coolers can all just be picked up and moved when the bottom of the car rusts to pieces.
Mine's got a completely standard engine, and (touch wood) I've never had any real engine issues over many trackdays.
Ridiculous engine mods are great when they work, but when they don't they'll cost you thousands unless you can do all the work yourself. Do suspension, brakes, windows, seats, wheels and possible a bolt-in cage. That'll last a long time before you get bored with it, then maybe consider doing something to the engine.
Posted 4th Dec 2011 at 09:17
Post #107
Wouldnt an electric water pump simply remove the parasitic drag from the cambelt and cause the alternator to have extra drag?
Posted 4th Dec 2011 at 12:17
Post #108
And be more likely to fail I'd imagine.
Posted 4th Dec 2011 at 12:34
jimmyhackers
Post #109
http://www.daviescraig.com.au/ have a look at theri website, see what you think
its all down to speculation really atm. the other things on my want list will probly be aquired first.
my main concern is reliability/longevity. im interested in them becuase they seem a relatively new tech that not many people have looked into yet, im just interested (and willing) to "test" it out. the install seems fairly uncomplicated. involves plumbing the pump in low down. removing the original waterpumps impellars, removing the thermostat, wiring it in to new temp sensor and your old rad fan. bleeding the system. test drive Smile
yes your right. however the electric water pump works as and when needed and far more efficiently than a mechanical pump. if im right its 15v at 10amps is 150w for the pumps max power and 15v at 12a is 180w for the controllers max power. so 330watts is max power taken. if im right thats 0.4ish bhp so lets take into acount the alt loses and call it 1bhp max. seeing as this does upto 5 litre engines i dont think ill be running anywhere near max current.
i dont expect massive power gains or any noticable ones. what i hope for is a a much more efficient cooling system. as in i get to temp quicker (reduces engine wear) i dont suffer from hotspots on shutdown (runs on afterwards). sitting in traffic i wont overheat or need to put my heater matrix on full blast. with its increased cooling capacity theres a possibility for a smaller radiator to reduce front end weight and would leave extra grill space for an oil/forced induction intercooler
it comes with a programable controller box that takes controll of the pump and your exsisting rad fan. so you can adjust it to run how you want or easily transfer it to another engine. this box also comes with a warning light tht you can extend to your dash board (most definately needed if im testing this one out)
i have another mad crazy scheme going with my 1.4 atm to make a steam turbine generator powered by the hot exhaust gases to replace the alternator. this would negate all electrical systems power drains. so far ive got a constant 110psi of steam coming out a 1/16 outlet/nozzle. but due to lack of funds for some unknown reason Razz i cant afford the closed loop tesla turbine atm, which is pretty much all i need to continue. so currently i have a rather large kettle/steam cleaner and a pile of old but squeaky clean a/c unit bits.
next step is probly a new lambda sensor (aim low)
seats
bonnet
windows
in that order
Posted 4th Dec 2011 at 13:35
Post #110
Hmm, I think there's either some very flawed logic there or I'm missing something.
When you say it "works as and when needed" - a water pump is *always* needed, else the water in the block will heat up and boil almost immediately and your block will crack. The idea of a water pump is to keep the water moving around the engine and so regulate the temperature, turning it off even for a few seconds could be disasterous.
I wouldn't rely on a 150W pump to filter my pond, let alone move water reliably around a five litre engine, that just sounds ridiculous. Quite some pressure is needed to make sure water is pushed up through a block, out into the heater matrix and back again, I'm not sure I'd fancy anything other than the torque of an engine to do that for me.
How will it get to temperature quicker? How will it stop you overheating in traffic? How does it have "increased cooling capacity"? It's a motor, not a radiator. It doesn't cool anything. Your radiator is responsible for cooling the water, so how is a different motor going to allow for a smaller radiator, which will in turn mean you won't overheat so much?
Hmm.
Posted 4th Dec 2011 at 13:58
Post #111
It's like talking to a brick wall Owain, you'd be better off trying to turn Rikky straight.
Posted 4th Dec 2011 at 14:33
Post #112
oh no you didn't girl
Posted 4th Dec 2011 at 14:34
Post #113
Jesus, in that case I plain and simple give up. Hopefully he'll concentrate on his flux capacitor idea instead then.
Posted 4th Dec 2011 at 14:36
Post #114
LOL
Seriously, the pump on the rotary only takes 3bhp, so a touch over 2kw, at 6000rpm (I know that 'cause the belt snapped on the dyno) and that's a pump that has to deal with idling at 900rpm and full chat of 9krpm+
So, gti6 pump pushing enough water to cool 100bhp less and dealing with lots less revs....how much do you reckon that absorbs...
Dunno
Not sure where this magic 10kw gain is going to arrive from, bar magic fairy dust. And advertising bumph.
Posted 4th Dec 2011 at 14:45
Post #115
Maybe that's the gain when coupled with an electric supercharger?
Posted 4th Dec 2011 at 14:47
jimmyhackers
Post #116
its almost like when they replaced belt driven fans with electric ones. its not running when it doesnt need to be.
however this pump is always running and works on a duty cycle so the speed will ramp up if needed. this means your cars coolant can be managed more effectivly.
the oem water pumps main limitation is its link to engine speed. great as you get more cooling at higher revs. however if you go from a stonking it around to sitting idling in traffic your engine block is still very hot and your pump is running at its slowest. the same way if its a hot day and your sitting in traffic your oem water pump is running at its lowest hence some people putting on the heaters as a backup.
this same limitation of being linked to engine speed means the pump design on most cars is a happy medium (gives more than adequate flow throughout rev range) whcih means its inefficent
your cooling system also relys almost soley on the thermostatic valve to regulate tempreture. i would hope an electronic system would be able to maintain a constant 90 degrees better
this is one of the last things on my wish list right now.
and i wont mention it further untill ive gone and done it probably in a year or two (after ive finacially recovered Razz)
Posted 4th Dec 2011 at 15:01
Post #117
Rubbish. If you're in traffic the engine overheats because there's no cool air coming into the rad, not because your water isn't moving quickly enough.
Posted 4th Dec 2011 at 15:06
Post #118
^What he said, nucleatic boiling takes care of any hot spots and those don't reappear because the engine is making bugger all heat anyway.
Posted 4th Dec 2011 at 15:11
jimmyhackers
Post #119
yourt right i didnt explain properly. the electric controll box takes over controll of your rad fan aswell. this is one of the reasons it can maintain your coolant temp better i.e. when your sitting still it can run the pump hgigher or choose to switch the fan on.
the box is fully programable so you can decided on pump duty cycles, coolant target temps and fan on temps, how long you want the pump to run on for after engine shutdown.
Posted 4th Dec 2011 at 15:26
Post #120
Okay then, you fill yer boots sunshine. I'll look forward to the "new block required, will pay up to £4000" post when it inevitably fails.
Posted 4th Dec 2011 at 15:32
jimmyhackers
Post #121
youll be waiting at least a year for that joy. many other things right now are higher priority on the wish list
Posted 4th Dec 2011 at 15:37
jimmyhackers
Post #122
argh theres a phase one v6 on ebay. i should just get that Razz
Posted 4th Dec 2011 at 22:27
ballardpaul
Post #123
Do it and move all your shiny bits over Yes
Nissan 350Z (300 BHP)
Posted 4th Dec 2011 at 23:20
7057sam
Post #124
Maybe you should just go back to smoking weed !
Team rallye,built for track
Rallye dead Sad
Secret Team Astor...
Posted 5th Dec 2011 at 00:26
Post #125
Get the V6, throw the engine away, build up a new V6 from parts from Peugeot and fit that Yes
Posted 5th Dec 2011 at 07:56
