Author Subject: where is the ignitor for the coil on a gti-6
fatlapit
as above really as i`m wiring in my ecu and it says do not wire directly to coil as it has no built in ignitor.
So is the ignitor part of the coil or does it not have one?????? or can i run like a 406 8v turbo set up?
how ever i do not want to do this as i want to keep the wiring neat. plus my turbo would get in the way!
Posted 24th Nov 2011 at 15:28
direct drive from the standard mm ecu.
Posted 24th Nov 2011 at 15:31
fatlapit
ah welshpug we meet again lol
cheers buddy so guess i need to convert to ht leads n that???
Posted 24th Nov 2011 at 15:35
yeah and some sort of ignition amplifier most likely, best off speaking to the seller of the ecu.
Posted 24th Nov 2011 at 15:40
fatlapit
its adaptronic mate,
do you know any ecus that will run the engine with a built in ignitor
Posted 24th Nov 2011 at 15:50
if you want to use all the standard components then probably a dta s60 emerald k6 or omex 710.
Posted 24th Nov 2011 at 17:52
Yeah, DTA will do that just fine.
Posted 24th Nov 2011 at 18:17
fatlapit
omex is mega bucks + you need trigger wheels n stuff for it,
take it dta has built in ignitor then??
Posted 24th Nov 2011 at 18:48
no need for trigger wheels, just use the standard flywheel.
Posted 24th Nov 2011 at 19:06
fatlapit
oh must of mis read the omex web site!!!
Posted 24th Nov 2011 at 19:27
