Author Subject: advice please
mick1989
driving down the bpas the other nite in my friends new phase2, the car was holding back. as we come to a stop we heard a tappin knockin sound comin on and off. it would stall now and then when stopped. so we slowly got it bk home. when he started it in the morning the amount of smoke it was chucking out was untrue. have you guys any advice on what it can be
Posted 23rd Nov 2011 at 17:28
miss timed cambelt?slipped belt?
Posted 23rd Nov 2011 at 17:31
mick1989
we thought that cambelt pins all line correctly. it was running great. as good as mine. but started makin a racket
Posted 23rd Nov 2011 at 17:38
mick1989
could it be the bottom end
Posted 23rd Nov 2011 at 17:56
vernam616
I reckon theres no oil in it
Audi S3 Black Edition
mick1989
yes its full with fresh oil
Posted 23rd Nov 2011 at 17:59
antcla.85
Head gasket
Life is short, make it interesting
Buy a Peugeot!
Posted 23rd Nov 2011 at 18:04
Loose sparkplug bouncing up and down slowly destroying the coilpack?
iplay
holding back could be a catalytic converter hex core turning 90 degrees ... this would then create someting similar to a hydro lock with exhaust gases causing a valve to warp or even worse ... split cat and centre box and shine a torch to check the orientation of the hex core (not sure the correct name). this was the cause of pete engine failiure and the car holding back was down to the core rotating 90 degrees.
Posted 23rd Nov 2011 at 18:08
mick1989
its only holding back sinse its made the noise. its white thick smoke thats only just accured after driving home with the knock. it will start now but not very easy.
Posted 23rd Nov 2011 at 18:31
