Author Subject: Installing brake hose, npt thread query
eddiebeano
Hi all, I understand on a wilwood calipers the fitting for the hose on the caliper is an npt thread. Do I need to use thread tape on them? And what should they be torqued up to? Also I have green stuff pads, are they any good or should I invest in something better and flog them? Cheers,
Ed
team: Stealth Ninja
Posted 21st Nov 2011 at 01:48
standard ferodo premiers should suffice in those calipers! certainly over greens...
no need for any thread compound, its a tapered thread.
Posted 21st Nov 2011 at 09:56
eddiebeano
Ok cheers, so are they just nipped up? Obviously the thread only goes half way in due to the tapering, before you can no longer turn it by hand, but how far should it go beyond there?
team: Stealth Ninja
Posted 21st Nov 2011 at 11:44
Just nip it up with a short spanner, if you 'Gorilla-Grip TM' it up you will snap something.
Posted 21st Nov 2011 at 16:08
Wilwood fittings normally have a pre-applied sealant to seal the leak path on the thread root in case you get it a little wrong, but tbh, NPT fittings are more of a 'done by feel' than by torque, there's too many variables for an accurate torque figure.
As daveyboy says, the best way is to just screw it in by hand and then nip it up with a short spanner so you can't strip the threads.
And no, they're crap, I'll give you £50 for 'em, so long as you throw in the calipers Whistle
Posted 21st Nov 2011 at 16:18
eddiebeano
So it should look something like this when tight?
Ha nice try Phil Wink
team: Stealth Ninja
Posted 21st Nov 2011 at 23:36
Usually go in at least 4-5 turns minimum
Posted 22nd Nov 2011 at 01:48
