Author Subject: Water problem
metbianco92
Hi mates i have a problem on the passenger side:/ This week in malta the rain has been goign non stop and on the passenger carpet i am finding a lot and a lot of water:/ i dont have an idea where its coming from. I have just changed all the rubber seals of the doors so i am sure that its not coming from the passenger door. Floor board has no holes and the car has no rust whatsoever:/ Any ideas where i can look ? pls help Sad
matthew
Posted 18th Nov 2011 at 11:58
look behind the door card, damaged plastic sealing sheet will let water in.
Posted 18th Nov 2011 at 11:59
T400 PUG Banned!
check the bulkhead area there are alot of holes for stuff down into the passenger footweel from there. mine leaks like a b*tch at mo. common prob i think as rust was already there when i got it.
Posted 18th Nov 2011 at 13:06
ian7675
Techno Viking
Do you have a sunroof?
Less than 24 hours to go!
Posted 18th Nov 2011 at 13:26
tishockin
i just had this exact problem with my driver side. it will be the inner door lining under the door card.
you will problably find that the seals have fallen off and this lets water that runs in past the window, run into the car as it lands on cables/wires within the door.
the seals are ment to stop the water from flowing all the way to the door card by blocking its path and directing it back to the outer door skin where it can run out the drain holes.
with the seals gone ital just run in out of the door speakers and fill your footwell.
easy fix tho, just take the door card off and real seal the inner linning with some sort of waterproof sealent. i used bathroom stuff and its been fine since
Posted 18th Nov 2011 at 17:23
metbianco92
thanks a lot will get it fixed next saturday and hopefully its the problem your saying heh. Its really a pain in the ass drying the floor mat at 6 oclock in the morning heh and dont forget to mention the bad smell the carpet leaves as it starts to dry heh. Hopefully will have no rain this week in time for me to fix itSmile
Thanks Met
matthew
Posted 19th Nov 2011 at 23:39
Also worth taking the door seal off and squeezing the seal together so as to create a tight fit when re fitted ? Once removed and squeezed tight use a hammer and piece of wood to bang it back on the door frame. This will ensure a correct fit and should stop the seal filling with water and dumping it in the car.
The seals don't like being removed and put back on badly ? If you look at the seal it has holes in the top of it which once fill are designed to allow water to flow out and out the car, if the seal is not fitted correctly it won't do it's job Thumbs up
Posted 19th Nov 2011 at 23:44
