displaying posts 1 to 25 of 49
Author Subject: carbs and cams
maddriver9
is anyone running weber carbs and cams as oppossed to throttle bodies and cams.
are they just as good at uping the bhp.
im thinking of doing this as i can not afford tbs and managment and the carbs seem like a cheaper option.
what sort of spec and gains are to be had
i dont want anything wild, somewhere around 200 bhp mark would be nice.
any advice ?
178bhp 205gti6
¼ mile in 14.2
Posted 16th Nov 2011 at 18:41
matty_rallye
Matt Holley used to run carbs on his 2.1 gti 6 engine, then changed to itb's. Trouble with carbs is to get them set up 'well' you are really best to run an ignition ecu. I think tho that once youve forked out on the carbs, manifold and other bits needed, got an ignition ecu and had it mapped you may as well have gone that little bit furthar with throttle bodies. You will never get it to run aswell, which if used just as a track car might not be so noticable, but if used on the road it certainly would be!
2.1 16v 306 Rallye.
Posted 16th Nov 2011 at 19:18
rallyeash
if your going to run carbs you need a ignition ecu for a gti6 engine ideally, the dizzy converters are pants and you
will loose everything your trying to gain.
as above once you've bought the full carb setup, ignition ecu, wired it up and had it mapped might aswell of gone down the TB route.
try pick up a second hand set of satchell thottle bodies complete with inlet and trumpets, just as good if not better than jenveys and dont carry the same price tag.
309 3dr K20 Type R
Posted 16th Nov 2011 at 20:19
maddriver9
yeah i know what your saying, but second hand webers go for about £300 were as tbs are about £600.
Then there is management, say omex at £600 plus fitting.
i dont know how much an ignition ecu is but i imagine its half the price.
178bhp 205gti6
¼ mile in 14.2
Posted 16th Nov 2011 at 22:18
Colins bodies are £650 new, DTA S40 is £500 new, ignition only is £400 iirc.
How did you get 178 already?
one massive plus point of well mapped bodies is that they will potentially use less fuel, whereas carbs will 100% use lots more fuel.
Posted 16th Nov 2011 at 22:41
maddriver9
i dont know how its made that power ?
got a great price i think on jennys £335+vat and omex 600 £545+vat
i know that there is a bit of work to be done as well but at that price why mess about.
178bhp 205gti6
¼ mile in 14.2
Posted 17th Nov 2011 at 21:40
Don't forget all the hidden extras, backplate, trumpets, linkages, sensors, TPS, coilpack, dome filter, plug leads, loom...
Posted 17th Nov 2011 at 22:09
maddriver9
yeah but i can sort most of that out myself so it wont be a massive amount more, mostly the map that will cost .
178bhp 205gti6
¼ mile in 14.2
Posted 17th Nov 2011 at 22:16
Get the Jenvey linkage, when it comes to balancing it all up and mapping the RR operator wont thank you if he has to p*ss about with some fiddly homemade Meccano shite. It will save you money in the long run and be safer as the mechanisim is very unlikely to bind and jam your throttles open.
Posted 17th Nov 2011 at 22:20
rallyeash
+1 buy a proper linkage. one place where you shouldnt try save money
309 3dr K20 Type R
Posted 19th Nov 2011 at 11:08
maddriver9
yeah i will be doing things proper, think i might just go to town and build a monster, aim for around 250bhp.
you only live once.
178bhp 205gti6
¼ mile in 14.2
Posted 23rd Nov 2011 at 19:21
b11 bob Banned!
you only live once.
Im running carbs and have heard all the crap on here about how tb are going to give you this and yet there is no gti6 engine on here running on tbs giving 213 bhp yet ive got that on a standard engine by running carbs and thats with a dizzy adaptor
If you want to save money the best option for you is twin 45 carbs but try to get hold of delroto carbs because they are better.If you got more money than sense go for tbs like the majority on here.The key to a carb set up is the Dizzy which a lot of people on here cannot get right and end up condeming carbs and going down the tb route and upseting their bank balance.
Tbs will give you better fuel economy sharper throttle response over carbs but the top end power and torque will be the same as carbs.Carbs are easy to set up once they have been rolling road tuned.Tbs to set up correctly will need mapping to suit your application but most rolling road tuners never map tbs all they do is copy a another map onto your ecu from a previous gti6 that was running tbs hence why they rarely make over 200 bhp
The choice is yours but to me its a no brainer
205 GTI6 235 bhp at 7400 rpm
Posted 4th Dec 2011 at 13:31
ballardpaul
And breath.
Nissan 350Z (300 BHP)
Posted 4th Dec 2011 at 16:47
yippeekayay
ballardpaul wrote:
And breath.
you should see his opinions on buying stuff...." how to make friends and influence people " might be a good chrimbo present for him... after I have read it of course!!!
x box "yippeekayaymofo"
Posted 4th Dec 2011 at 16:52
What bore are the bodies that Colin uses?
Are they the esprit ones which i'm sure i've seen mentioned somewhere?
Would they be running 8 injectors setup?
Sorry for so many questions, just read that i'd probably struggle to get more than around 50bhp per cylinder with 40mm bore TB's, i'd be hoping for a bit more than that with the cams i've got and the engine which i will be building eventually.
Posted 4th Dec 2011 at 17:51
rallyeash
yep esprit items, can only run 4 injectors in the standard position. 45mm tb's also
309 3dr K20 Type R
Posted 4th Dec 2011 at 19:57
dav1
213bhp on std engine and carbs LOL
230bhp 205 gti6
Posted 4th Dec 2011 at 20:00
maddriver9
hes going take you down baz
178bhp 205gti6
¼ mile in 14.2
Posted 4th Dec 2011 at 20:02
Cheers Ash. Thumbs up
Posted 4th Dec 2011 at 20:03
dav1
think i best sell all my tackle, buy some carbs and a std engine. plus save bit of money at the same time win winCrazy
230bhp 205 gti6
Posted 4th Dec 2011 at 20:05
matty_rallye
Sounds like an optimistic figure. Confused
2.1 16v 306 Rallye.
rallyeash
b11 bob wrote:
you only live once.
your car is not making 213hp with a standard engine on carbs. FACT!! either some very inaccurate rollers, or some bullshit going on... i'd be supprised if its even making standard power with a converted dizzy.
309 3dr K20 Type R
Posted 4th Dec 2011 at 20:07
matty_rallye
rallyeash wrote:
b11 bob wrote:
you only live once.
What i was trying to say, with slightly less tact LOL
2.1 16v 306 Rallye.
Posted 4th Dec 2011 at 20:10
dav1
Only one thing for it B11 BOB a race. your 213bhp 205 against my 219bhp tb,cammed,pistons,etc 205 if yours is 213 then there should be nothing in it.Thumbs up
230bhp 205 gti6
Posted 4th Dec 2011 at 20:11
maddriver9
sounds fun
178bhp 205gti6
¼ mile in 14.2
