Author Subject: MAP Sensor
MAP sensor needed asap.
Removed from the car today, its this one I need. Bosch 0261230012
Thanks people Smile
Posted 15th Nov 2011 at 10:27
mcfc1987
I think i have one in my garage somewhere. will be home for 4 if you want me to check. don't think your to far from me either
Posted 15th Nov 2011 at 10:41
jonnie205
what phase?
Posted 15th Nov 2011 at 11:04
jonnie205 wrote:
what phase?
Need to check this...
Car is phase 3, but I think when the engine was replaced before I got it, it has a ph2 engine.
Will check tonight.
Posted 15th Nov 2011 at 11:09
Have a nosey on the block for the year stamp.
There is a chance it could be cobbled together with a host of different parts for the original engine, so look at the cam covers for the stamp there also. If they tally up it's a strong possibility that it is going to be mostly that year.
  • Posted 15th Nov 2011 at 11:12
    Where will they be Dan, easy enough to see?
    Posted 15th Nov 2011 at 11:15
    The one the block is at the front, bottom to the right of the oil filter. Whip the undertray off if you are blessed to still have one. They are quite prominently stamped near the J4RS bit, so even with dirt you should see it otherwise a wipe with some brake cleaner will show it up. If you can make out the engine number at the same time I will be suprised. They rust over.
    On the cam cover, it is underneath the coil pack cover on the recess. There is a small dial with the year stamped in there.
  • Posted 15th Nov 2011 at 11:25
    Thanks Dan, will check it out.
    Even if they are the same, it could still be that the rest is phase 2?
    I know the phase 3 (crank sensor I think) wasnt the right one. Unless the guy sent me a phase 2 one Doh
    Posted 15th Nov 2011 at 11:28
    Rich E Forum Admin
    Don't bother looking at dates on the block and/or cam covers. It could quite easily have had the ECU loom changed, block changed, cam covers changed or whole engine changed.
    Look at the MAP sensor plug. If it has square edges with a metal clip then it's phase 2. If it has rounded edges with a plastic clip then it is phase 3. There are no half-way house looms, it will be either phase 2 or phase 3, which will dictate which sensors you have.
    Posted 15th Nov 2011 at 11:56
    Top man, thanks Rich Big grin
    Posted 15th Nov 2011 at 12:02
    bump, pics added to first post Smile
    Posted 15th Jan 2012 at 18:55
    gota6again
    Have you looked at my breaking thread? Not 100% if the MAP sensor I have is the same? The plug is rounded as yours but there are a few differences, mine seems longer?
    Dee
    Posted 15th Jan 2012 at 20:14
    I thought mine was longer too Hmm
    Can someone confirm that is actually a MAP sensor, hope I havent got the wrong one Laugh my ass off
    Edit: Just checked your thread, thats the one Im thinking of! Swear mine used to be like that. Just checked my thread, and must of been confusing it with maybe my old car as the MAP sensor pictured above, is definitely the one thats always been fitted Smile
    Posted 15th Jan 2012 at 20:17
    gota6again
    Dunno I'm even more confused now LOL
    Well if it is the right one it's here, if it's not the same, it's still here LOL
    Posted 15th Jan 2012 at 20:30
    Laugh
    Sorry mate. What I mean is, I'm after the MAP sensor pictured above, not the longer one you have Thumbs up
    Posted 15th Jan 2012 at 20:48
    gota6again
    Ah, no problems Thumbs up
    Posted 15th Jan 2012 at 21:06
