Author Subject: New trailing arm bearings
cornish_pug
Should the new outer bearing sit 0.5mm in from the outside of the main tube or the outer crossmember tube.
Team Diesel
Posted 12th Nov 2011 at 12:05
jeffers Forum Admin
Half mm in iirc, check welshpugs rebuild faq to be sure! Thumbs up
Team Running Engine again!
Team Negative Camber!
Posted 12th Nov 2011 at 12:14
yep, basically at the end of the chamfer Smile
Posted 13th Nov 2011 at 15:44
