Author Subject: knocking from rear
mike rallye
hi guys
i have noticed i got a knock coming from the rear of my car and it getting that annoying i need to sort it out soon. i have had the car on a ramp with a pry bar in on the rear mounts to see if there knackered or broke but i cant seem to fault them.
is there a chance the rear mounts are knackered or could it be rear shocks?
Posted 11th Nov 2011 at 22:42
mik
I have it too - going over bumps it sounds like exhaust is hitting floor, but isn't. I've not got any play either, so had been difficult to diagnose.
Options I'm investigating are -
ARB end plate/bolt secured.
Knackered rear mounts.
I've ordered new mounts from Pug and am hoping to get it sorted soon.
Cherry Rallye SOLD
Posted 11th Nov 2011 at 22:52
mike rallye
how much were the mounts from pug?
Posted 11th Nov 2011 at 23:00
mik
Not cheap - can't remember exact price (still waiting for the dealer to assemble all the bits) at least £200 for the 4 mounts IIRC.
Cherry Rallye SOLD
Posted 11th Nov 2011 at 23:48
jord294
£90 each for the front and £40 for the rear
Posted 12th Nov 2011 at 06:56
anth
Tap up justinaccurate he gets the parts cheaper
Posted 12th Nov 2011 at 07:48
Loose bolt at one end of the damper? Had that one mine, so the damper was moving side to side, only by a millimetre or so but was enough to cause a hefty knock.
Posted 12th Nov 2011 at 09:29
pooouk
Also check the damper bushes. I've got a knackered one on my Bilsteins and it knocks like mad.
Nick
AKA nick on 205gtidrivers.com
Posted 13th Nov 2011 at 15:39
mik
Good tips - maybe we should have a FAQ for rear beam knocking. I'd looked before and couldn't find one. Am definitely adding above points to my list (even though my rear bushes look nasty and need doing anyway).
Cherry Rallye SOLD
Posted 13th Nov 2011 at 22:31
mike rallye
bit of an updated with a result
well i managed to get the car on me ramp today in work and look for this knocking.once the back wheels were off the floor i found loads of play in the bushes of the rear shock.worn and perished.
my next questions is- i have knoi gas shocks on the back(were on the car when i bought it),would you recommend to get the new bushes or should i buy couple of new shocks?
what sort of rear shocks should i go for,i something that will work well and be ok for when going on the track.
Posted 15th Nov 2011 at 19:18
jord294
genuine replacement shocks are more than ample imho
i've found that the only reason the bushes deteriate (sp?) is that the bolts have not been tightened with the weight of the car on the wheels
Posted 15th Nov 2011 at 19:31
mike rallye
ok thanks for that andy, and i will defo make sure the job done right this time.
Posted 15th Nov 2011 at 19:49
greenbelt
anth wrote:
Tap up justinaccurate lukejenks101 he gets the parts cheaper
Wink
Standard Black 6
Black HBSC6 Smoke
Posted 15th Nov 2011 at 20:00
mike rallye
for got to ask, will the standard rear shocks be ok even those the rear beam is lowered?
Posted 15th Nov 2011 at 20:19
jord294
yes mate
Posted 15th Nov 2011 at 20:49
pooouk
The bushes are cheap enough. £6 each plus post direct from Bilstein, so I'm guessing a similar amount from Koni.
Nick
Posted 22nd Nov 2011 at 15:26
mik
I'm doing my rear beam mounts in the next couple of weeks, but might as well check these too as they could be the source of my noise.
Would anyone know whether these bushes are aval separately at Pug (i.e. without having to buy new shocks) or would the Koni/Bilstein ones fit?
Cherry Rallye SOLD
Posted 22nd Nov 2011 at 18:50
mike rallye
the knocking on mine turned out to be my rear shockers bushes worn. i believe you can get the the bushes if you got standard shockers fit
Posted 22nd Nov 2011 at 19:44
mik
Thanks. I have standard rear shocks. I will ask Pug and see if the shock eyelet bushes can be purchased separately.
Cherry Rallye SOLD
Posted 22nd Nov 2011 at 21:49
