Author Subject: Hi Spec ultra lite calipers
rallyeash
i will shortly be taking these calipers off my 205 rallye as im going to be fitting 15" C5 steels and going bigger brakes. i had these fitted on 266mm discs with custom made brackets. i will just be selling the calipers, braided lines and will include the nearly worn out mintex 1155 pads.
the calipers themselves are about 2 years old but probably only covered 2k miles inc trackdays.
heres a pic of them when i purchased them, will get some more pics soon but you get the idea...
£250 delivered
309 3dr K20 Type R
Posted 4th Nov 2011 at 13:23
simbob
Why would you pay 250 for these when you can get a 4 pot 406 setup with disks and pads for the same money ?? EXPLAIN !!
Happy to be back in a 306 again!
Posted 4th Nov 2011 at 15:26
Because these are lighter and fit behind spokes better iirc.
Posted 4th Nov 2011 at 15:38
Ed_van_dijk
And the 4 pots off a 406 squeak like a twat unless you spend loads on discs and pads and works out to be a bloody expensive brake set up for something not that brilliant!
Astor 6
Posted 4th Nov 2011 at 16:07
rallyeash
ligher, fit behind steel's with no spacers, don't squeel, list goes on
yes brembo's are always cheaper than hispecs, wilwoods etc.
309 3dr K20 Type R
1. Because the 406 setup isn't that good - not that good at braking and very heavy.
2. Once you factor in a disc and pad combo on the 406 calipers that don't squeal the price is bugger all difference.
What size are the calipers? Any idea what size disc they'll take?
Posted 4th Nov 2011 at 16:08
LOL @ Simeon = owned
Posted 4th Nov 2011 at 16:09
Also because Hi-specs only come up every so often, every bas**rd and his nan has got a set of 406 Brembos in their shed.
Posted 4th Nov 2011 at 16:16
Ed_van_dijk
Unless they flogged them to a chav with a turbo saxo for £305 Whistle
Astor 6
Posted 4th Nov 2011 at 16:21
ROBBED.
Posted 4th Nov 2011 at 16:22
eddiebeano
So what would be need to fit these to a six with the standard 283mm discs?
Ed
team: Stealth Ninja
Posted 4th Nov 2011 at 18:39
rallyeash
just some brackets knocked up Smile
provisionally sold atm
309 3dr K20 Type R
Posted 4th Nov 2011 at 18:40
rallyeash
sold to a member on 205 driver's
309 3dr K20 Type R
Posted 6th Nov 2011 at 23:46
