Author Subject: Lower Strut Brace
speedo306
Hi guys would just like to know if the lower strut brace helps to calm vibrations.
RJ
Posted 4th Nov 2011 at 00:44
aaron6
I would have thought it may make it worse by making the car more solid. But chances are it would make no difference at all.
Posted 4th Nov 2011 at 08:43
It can help shut up some suspension noise as it shifts the resonance frequency upwards due to stiffening the mountings, it's probably not going to help with any vibrations you can feel in the cab though.
Posted 4th Nov 2011 at 09:33
speedo306
Thanks. Is there any 'good' brand of lower strut brace that does not touch the bottom sum pan of the engine.
RJ
Posted 4th Nov 2011 at 17:09
There is only one "brand" of lower brace as far as I know, and that's Phil. Mine knocks against the sump a little when idling, but it's not a problem.
I don't really think they're going to make any real difference to sound other than that, I'm sure I could sort it if I were that bothered.
Posted 4th Nov 2011 at 17:31
There's a little bit of adjustment on the bolt holes, just slack them off slightly and give it a good tug Whistle:
Posted 4th Nov 2011 at 17:42
