Author Subject: Caged cars/ manual windows
pugheaven
I know it's in the wrong section guys, I just haven't had the time to pay yet!
How do you guys with the custom cages get on with using the manual window winder?
Does the cage get in the way when winding the window up/down?
Thanks
Ollie
Posted 31st Oct 2011 at 23:30
Thanks
Ollie
Yes, it gets in the way, you can pull the winder off and put it back in such a way that it misses the cage when the window is fully up, and you can get them up and down without it hitting the cage but it really is a squeeze. I found cracking the door open a bit to wind the windows worked for me.
Posted 31st Oct 2011 at 23:39
pugheaven
Would it help if the winder arm was shorter? Or is it the depth of the winder it's self?
Really don't want the fronts polycarb with the little slide hatch!
Electric windows dare I say it :-X
Posted 31st Oct 2011 at 23:49
You'll ruin polycarb windows if you have them slide up and down, it'll put scratches in 'em and you'll not be able to see through the buggers after 6 months.
Posted 31st Oct 2011 at 23:53
pugheaven
Sorry what I ment was If I can't use the winders I would go to fixed windows with the little hatch!
Or I can add some weight and fit electric windows!
Posted 1st Nov 2011 at 00:14
Fixed lexan & slidy hatches ftw. It's the only way.
Posted 1st Nov 2011 at 08:15
Or just stick with electric. Not sure the weight difference is huge over windy glass windows. Obviously a lot over fixed lexan.
Go electric and make sure you shave your head, blow your nose, remove your false teeth and clean out your ears. Job done - just look at Phil M to see what to aim for.
Posted 1st Nov 2011 at 09:46
But needing winders or electrics means keeping the original door cards, do they even fit with a cage? I'd just get rid of the cards and have flat sheet so you've got more room.
Posted 1st Nov 2011 at 09:47
306weasel
Standard doorcards won't fit if the cage has door bars. My cage was made with a door bar lower than usual so as not to obstruct the window winder and armrest
Car#1 306 HDi Meridian 5door, 133Bhp, 225lb.ft Ecosse R/R 20/3/05
Car#2 306 1.4 3door track car with Gti6 power. 167Bhp, 134lb.ft Ecosse R/R 21/10/07
Car#3 Grand Scenic 1.9DCi (Expanding!) family mover.
Posted 1st Nov 2011 at 10:32
leccy windahhs ftw.
Posted 1st Nov 2011 at 11:28
Why?
Posted 1st Nov 2011 at 12:46
Are the winders and electrics not mounted to the card?
Posted 1st Nov 2011 at 13:11
no.
Posted 1st Nov 2011 at 13:13
Fair. Then fill yer boots.
Posted 1st Nov 2011 at 13:15
Ta-da Wizard
Posted 2nd Nov 2011 at 09:30
Eh Chris, why did you not put the handle surrounds in? I did that with mine, and it looks far more pro Yes
Posted 2nd Nov 2011 at 09:31
handle = does not compute Unsure
Posted 2nd Nov 2011 at 09:34
Yeah, but think of the extra weight Laugh
I didnt think I needed them, so I used them on my diesel (as they were missing on that)
My door handle? Ghetto door handles FTW!
Posted 2nd Nov 2011 at 09:58
no i mean
handle
i do not know what this means LOL i use pull rods on mine, extra light FTW
Posted 2nd Nov 2011 at 10:06
