Author Subject: Bianca Rallye
mcfc1987
Not much of a project compared to my last one and will be slow going but my aim is to keep it as standard but able to hold it's own on next years ring trip with the work lads.
Picked up this around a month a go. after an epic trip to get it i took it away knowing it needed a polish to get it white again and a wheel bearing doing but other than that looked tidy.
after owning it for a week it developed a pretty serious oil leak. turned out to be a leaking crank seal and rear cam carrier so included a beware cam belt and waterpump kit.
Then a few days later the battery completely died. checked for loose wires and made sure the alternator was still going strong. from what i could gather it was just a fubar'd battery. since then its been faultless and I've hopefully sorted out the things that needed doing.
First big change was kicked off this morning
removed the god awful chequer plate and the bucket seats as i am after a standard car. i was left with this, needs a good clean but i am chuffed!
next job is rear beam. will prob go for a refurbed one instead of rebuilding mine. before i do that i need to decide on ride height. this is third 6/rallye i have had and this is the first one i have experienced with suspension and i have been blown away with the comfort and handling. lowering will just be for looks really as ride wise its perfect.
Also want to loose the cyclones as i hate having unbalanced wheels
Posted 29th Oct 2011 at 21:23
mik
Very nice!
I know what you mean about cyclones. I'm about to tackle this in earnest and the end result might be getting something else, as even if I get money back for rubbish balance attempts, it is still the time and faff to sort it.
Like the black mask crystal headlights too, make for a nice clean modern look.
Cherry Rallye SOLD
Posted 30th Oct 2011 at 08:42
honestly3k
Maybe just have the cyclones balanced? LOL
Lovely car though, i definately prefer white rallyes over the other two colours
Get the side strips colour coded and they look epic
Posted 30th Oct 2011 at 08:46
davewagon
My cyclones stay balanced for about a week after I fork out for balancing, tired of it now (even though I think they are the best suited wheel for the car)
Some 7" TD pro 1.2s i think...
What wheels you thinking of going for?
Team: Moonstone GTI-6™
Team: Working air-con™
ian7675 wrote:
Posted 30th Oct 2011 at 16:49
Looks a nice straight car Smile
If you want to keep cyclones why not get the centres machined out,sure it was someone on here that did it and offered it as a service.
He machined them out so run of the mill pug centres fitted straight in Wink
Posted 30th Oct 2011 at 21:04
Carl Chambers
never had a problem with balancing cyclones! if done properly on a proper centre less wheel balacing machine then they are fine?
I know many tyre fitting places seem to stuggle with them but cant see why? I have the proper balancer here and never had a problem or had any wheel wobble with cyclones after I have done them?
to machine the centres out is a bit extreme?!
Carl Chambers
email; pugnacious.peugeot@yahoo.co.uk
C.M.CHAMBERS CARS
Peugeot Specialist
Tel; 01379 586101 after 6.30 or 07889 082466 anytime.
pugsport-racing.co.uk
Posted 2nd Nov 2011 at 21:14
rallyeash
same as that, the local tyre place just has an adaptor that fits on to house centreless wheels. no problems with them
309 3dr K20 Type R
Posted 2nd Nov 2011 at 21:22
mcfc1987
I will give a few places a ring tomorrow then and see who can do it
Posted 2nd Nov 2011 at 21:23
mcfc1987
probably up for sale, i am now biking to work and we use the Golf whenever we go out with the newborn. plus i fancy Jords 205
recent pics
some info
Bianca white 306 Rallye
125000 thousand miles
Serviced every 10K miles since may 2004 with Millers CFS 10w-40 competition fully synthetic oil for the engine and millers CRX 75w90 NT competition fully synthetic gear box oil, all filters and spark plugs done at the same time
At 100’000 a faulty cambelt kit was fitted and subsequently slipped, under warranty it had a full engine rebuild with new valves and tappets with a skim of the head, now drives better than ever
Mongoose exhaust system with a hoffman sports cat with a K&N induction which sounds lovely
Brakes are almost as good as my old brembos which is impressive for a standard sized set up, maxtorq grooved and cross drilled front discs and group N Maxtorq rear discs. Mintex M1144 pads all round with braided goodridge hoses.
Only suspension mods are OMP upper strut brace and PhilipM lower strut brace
Engine bay and transmission mods, engine earth kit in red, oil catch tank in red, body coloured cam covers and inlet manifold with a PTFE gasket to bring down running temps, also has a Griffith engineering quick shift, new lower engine mount.
External mods are all seen on the photo’s
Recent work carried out is as follows
Wheel bearing 119000 miles sept 2011
New cambelt and waterpump kit, lower crank seal, rear cam carrier 120’000, oil change and filters oct 2011
Battery replaced, new with a 3 year warranty oct 2011
Also has a fully working and built in bluetooth kit for your phone and has a cobra alarm and immobiliser fitted
Posted 20th Jan 2012 at 07:11
mcfc1987
£2k ono
Posted 20th Jan 2012 at 07:12
jord294
GLWS Big grin
Posted 20th Jan 2012 at 07:32
mcfc1987
jord294 wrote:
GLWS Big grin
although i have just seen that the 205 is now listed as sold on pistonheads lol, balls
Posted 20th Jan 2012 at 07:41
jord294
mcfc1987 wrote:
jord294 wrote:
GLWS Big grin
the buyer is collecting today. sorry
Posted 20th Jan 2012 at 10:13
tom275
Have you still got those Cobra seats?
Posted 2nd Feb 2012 at 18:32
