Still they feel a lot better since fitting the correct top cups.
there should be one there anyway....
need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets.
displaying posts 26 to 29 of 29
Pages (2): 1 [2]
| Author | Subject: Gaz Gold springs not rotating in top mount bearing? |
jungle jim wrote: I guess I can remove some of the movement by placing a large washer over the top of the damper underneath the top mount, that should give it some more area to press against. Still they feel a lot better since fitting the correct top cups. there should be one there anyway.... ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jungle jim
Senior User Location: Farnborough Registered: 12 Apr 2006 Posts: 796 Status: Offline |
welshpug! wrote: jungle jim wrote: I guess I can remove some of the movement by placing a large washer over the top of the damper underneath the top mount, that should give it some more area to press against. Still they feel a lot better since fitting the correct top cups. there should be one there anyway.... Bought them second hand so bits where missing, and no destructions. As usual you lot come through though ![]() Thanks for the help guys! ________________________________________ 200+ secret squirrels hiding under the bonnet with 4 wide mouth frogs... |
sounds like #70 is missing, the size of them is shown in the data here too, they're about 60p and the nyloc just under £2.#70 6949 11 PLAIN WASHER 14X38-3 #71 6946 19 PLAIN WASHER 14X29-2 ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
jungle jim
Awesome, thanks.Now if you can also arrange for it to stop raining for about 30 minutes... ________________________________________ 200+ secret squirrels hiding under the bonnet with 4 wide mouth frogs... |
Pages (2): 1 [2]
