Author Subject: Rear shock
cornish_pug
What are the symptoms of a knackered rear shock?
Team Diesel
Posted 25th Oct 2011 at 18:29
bouncyness, shite handling, understeer.
Posted 25th Oct 2011 at 18:32
cornish_pug
The shock creaks very loudly when compressed and, once compressed it doesn't really come back up again
Team Diesel
Posted 25th Oct 2011 at 18:42
is that with the damper removed?
Posted 25th Oct 2011 at 18:49
cornish_pug
No, on the car still.
Team Diesel
Posted 25th Oct 2011 at 19:01
More likely to be the beam siezing up, disconnect a damper bolt and see if it's the same.
Posted 25th Oct 2011 at 19:17
what phill said!
Posted 25th Oct 2011 at 20:38
cornish_pug
Took the damper off today and the noise stopped when I lowered the swing arm onto an axle stand. The damper was fairly easy to compress with one hand but it was harder to de-compress. Not sure how the damper should feel!
Team Diesel
Posted 28th Oct 2011 at 20:26
But does the beam make a noise when you move the arm, and do the trailing arms extend properly?
If you can compress and extend the damper by hand then that was not what was holding the suspension up.
Posted 28th Oct 2011 at 20:51
cornish_pug
No it's pretty much silent in movement when I move the trailing arm up & down with the damper removed. With the damper bolted back on the noise comes back. I can feel it coming from the damper when I put my hand on it and jack it up & down.
Team Diesel
Posted 28th Oct 2011 at 23:39
atterz
Also scalloping of the rear tyres!
owain wrote:
Posted 29th Oct 2011 at 19:10
