displaying posts 1 to 25 of 36
Author Subject: how hard is a gti6 cambelt to do!!!!!!
yippeekayay
Can someboy please explain why it appears that nobody seems able to time a gti6 engine up???
Certain reputable garages charge a substantial fee for doing cam belt water pump tensioners etc and time and time agian I hear that the belt snaps or is timed up wrong or as in my case the head gasket goes / head damage due to incorrect valve timing.
I have receipted cam belt change from the non mentioned "God of all things Peugeot" and in less than 2000 miles it developes dodgy starting, running on 3 cylinders then runs clear. then one day heading up the motorway at a steady 80mph a cloud of smoke engulfs the traffic behind and I drift off the m40 with the engine off to find the rad has pressurised up and dumped half the water from the cooling system out through the expansion bottle and out and under the car at a great rate of knots.
I let it cool down called a mate with a large drum of water and coolant top the car up and check for overheating. No sign of it so I drive the 15 miles to my mates garage and leave the car with him after doing the carbon monoxide test which blew purple in less that 2 seconds.
I phoned the god of all things peugeot and asked a price for a head gasket and am told it could be 700+ depending on bits. I also reminded him that the cam belt had only recently been done with him. so my trusty peugeot friend volunteers his services for a lot of peanut butter sandwiches and some pound notes.
A day later it is apparent (not appeared) that the head was not timed up correctly and that there was no slippage in the crank pulley. Upon removing the head 2 exhaust valves were found to be damaged as well as 2 buckets.
Now we can all argue that you cant warranty a cambelt as you cant guess how its been driven by the owner never mind owners. ( it had 2 owners straight after the cambelt change, me and A.N Other)
I am now down approximately £800 I feel I cant get anything back and I know I am not the only one. Is this bloke ( gods of all things peugeot) employing Monkeys to do his work because I cant imagine him making these mistakes. I had a good mate that bought a 205 converted rebuilt gti6 engine that let go after "minutes" that we couldnt get anywhere with.... So where you see praise be careful. it isnt neccessarily the truth.
I accept theres 3 sides to every story but is doing a 6 belt really this fragile!!!!
x box "yippeekayaymofo"
Posted 25th Oct 2011 at 17:58
rallyeash
ive only even done a cambelt on a 6 once, that was when i rebuilt a complete engine for a mate after having flood damage which resulted in an ovaled crank and 4 S shaped pistons!
i dont know that the fuss is about tbh. the crank pulley wasnt slipped so i put a drill bit in the hole, locked the cams in position,(then stripped and rebuilt) fitted the belt, along with new pump, tensioner, idler etc, tightened and job done. started first time and done 20k since!
309 3dr K20 Type R
Posted 25th Oct 2011 at 18:13
yippeekayay
my point exactly... it isnt rocket science so why all the failures!!??? because somebody isnt timing timing them up right in the first place??
Posted 25th Oct 2011 at 18:15
rallyeash
common issues being one of the cams "swinging" where people try the non lock or tipex method or bottom pulley has slipped.
ive always found it odd why theres such a thing about cambelts just on a 6 engine. i would do any other cambelt the same way on another car...
309 3dr K20 Type R
Posted 25th Oct 2011 at 18:19
spot on, too many last mechanics out there.
Posted 25th Oct 2011 at 18:31
mattgti6phase2
Mine was done by previous owner before I bought it. This was done by the god of things Peugeot to! I didn't have any issues just noticed it was retarded on the inlet cam when stuwee1983 recently changed mine (f*cking good mechanic) which hampered performance slightly!
As said above this shouldn't be happening No No
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 25th Oct 2011 at 19:11
Couldn't be simpler.
3 drill bits and if you use the newer plastic tensioner, it has a mark on it to show you how tight to make it.
I bought a 6 with a 10 month old bill for new belt, crank pulley etc. Hadn't done thousands of miles before it snapped but you could see it was done way too tight and the belt frayed and got caught.
  • Posted 25th Oct 2011 at 19:12
    hismastersfinger11
    just to add insult to injury with how easy it is to replace the cambelt, i'm the kind of guy that spends 2hrs trying to get a p-bush bolt back in and to be fair a head gasket took me a week but it can litterly be done by muppets with a book!!
    This site is my mechanical bible, Thank-you everyone!!
    Posted 25th Oct 2011 at 19:32
    gilesy
    The same god did my last cambelt on my rallye, and has previously done the belt on the phase 1 that I have now. I can hear the whine that Rich W told me was from the belt being done too tight.
    Posted 25th Oct 2011 at 19:43
    mechanical_repairs
    It must be me, the 100s of cars I have done admittedly a few have failed, not a day after or a few hundred miles later, it's years later or 30,000 miles later, which was the earliest one, the customer contacted me and I repaired the car under parts warranty (well known forum member). I get the parts free due to using backed up and warranted parts, I just have to swallow the labour in some cases.
    It must be me doing them wrong!
    Peugeot fit the belts when new and they failed before the due time, a lot of people moaned and few had them repaired under warranty or with a Peugeot goodwill gesture, then there are some people who have the mis fortune don't tell anyone who they should, ie the garage etc and moan on the Internet?
    I have as always treated my customers as fairly as I can, basically I am just like all of you, go to work to earn a living and as with any job you get happy customers and unhappy customers but I like to think I only have a hand full of unhappy customers. Things go wrong it's the way of the world, pointing the finger at me when the car costs money to be repaired is not my fault.
    Bad things always get overly publisiced, good things don't.
    I must be doing something right, I have worked for myself for a good ten years now and have made a lot of good friends through my customers, a lot of them off of here, most of my work is through recommendations and i get alot of repeat work.
    Said my piece.
    Carl
    Posted 25th Oct 2011 at 20:25
    yippeekayay
    Didnt name who I was getting at. And have had a number of people pm ing me who it was. I have defended you to people constantly over the last 2 years as I have been and am an admirer of the effort and skill that went into yr 205. I just cant stand by and watch people praising you when I am getting a phone call almost daily telling me yet another part of my head is knackered and going to cost another hundred quid.
    Whilst I accept that you know what you are doing, how could you not, but perhaps as stated in my post have you employed numpites to do work that you havent checked.
    I was with a friend a few months ago who I asked to contact you with reference to his gti6 engined 205 sh"tting itself after less than a lap of cadwell when you blatantly said you accepted no liability responsisbility. I told my mate that he should give you the chance to inspect it and find out what was wrong but he was so annoyed by your initial reaction to him when it dumped its oil trackside that he would never entertain this. It wasnt the customer service I expected from you and since seeing various other engine builds not one had a positive to say and have been talked about in this forum before.
    Yes I know peugeot had trouble but believe me most of it was with junior techs trying to do jobs on bonus and airgunning their way through it without due care and attention.
    I appreciate your slant Carl, I can see you go to work to earn a living as do a lot of people who have to work to pay for their cars to be repaired, and repaired again and again. You have balls or a front to stand up here, I dont know what gave away who I was talking about so that smoke led to you, the fire. you pointed the finger. I will just wear the 800 quid bill as my mate wore his 1500k and a number of others I can reel off over a grand each.
    I was quite lucky really,
    Posted 25th Oct 2011 at 21:51
    atterz
    Aye Carl, ill be over to p*ss you off again with the Rallye in the coming month!
    owain wrote:
    Posted 25th Oct 2011 at 22:00
    rallyeash
    im sure with that attitude you'll go miles
    309 3dr K20 Type R
    Posted 25th Oct 2011 at 22:27
    So as I read this your head gasket has failed at a water way and dumped coolant into a bore ? Thus causing a mis fire and poor running ? ? Could a massive failure not flood one of the bores and then almost hydro lock that cylinder damaging the valves ?
    Was the engine a tapper before it failed ?
    Is the gasket that has failed a proper 3 plate job from pug or has it all been apart before and a shite version been used ?
    I'm not defending anyone here just think some more info is required ?
    Posted 25th Oct 2011 at 22:50
    mechanical_repairs
    Andy, I take it you are referring to your freind who bought Jamie Tonks track car, I would have loved to have it back to look over the issue but what should I do, yes there you go, have fun thrashing it round the track and if it goes wrong bring it back, it has a lifetime warranty? Basically it never came to me, but the guy who bought the car off him after a second hand engine was fitted to it brought it back for faults etc, did you help fit that engine?
    Manufacturers have spotters out there that void there warranties on new cars should they be caught out on track! There is a limit to what anyone can can warrant.
    basically, your head gasket failed, you previously spent money with me on a timing belt kit, quite some time ago and it has something to do with me??
    Carl
    Posted 25th Oct 2011 at 23:10
    miles
    I've never known the fuss about timing these engine's, It's just a 16v XU engine fitted in millions of PSA car's and most garage's replace them weekly, Mind I know we don;t get many owners of 2.0 406's on here asking questions about them.
    But It does annoy me when I see tipex etc on the pulley's, there is no need 'please'
    www.pugracing.com
    yippeekayay
    it was one tooth out was breathing from the exhaust valves which pressurised the system... not made it jump a tooth, there was practically nothing in the bores. Like i previously said I am not turning this into a witch hunt. Deliberating it further would not achieve anything more than countless pros and con stories and I accept Carls arguement that a negative gets publicity more than a positive so dont need to push this further. my point is made. If he is getting monkeys to do his work then he needs to check the work. Hindsight on my half might have talked to him more about this but as detailed above I dont believe he would have come up with a solution,
    mechanical_repairs
    More than welcome mate.
    Carl
    mechanical_repairs
    Very true, such a good and simple way of timing them up. If it was an alfa twin spark then I suppose you can see why the diyers, use the tipes route.
    Carl
    Posted 25th Oct 2011 at 23:13
    yippeekayay
    Carl I didnt fit the engine but i drove the 300 miles to fetch it. I gave you credit of a decent response in your first post and it made me question my stance with you but you have just fired back in exactly the way you fired back at james about mr tonks car. That again substantiates my thought you didnt give a crap and you are showing it here. Hardly the:
    "I have as always treated my customers as fairly as I can, basically I am just like all of you, go to work to earn a living and as with any job you get happy customers and unhappy customers but I like to think I only have a hand full of unhappy customers"
    Posted 25th Oct 2011 at 23:18
    mechanical_repairs
    yippeekayay wrote:
    Carl I didnt fit the engine but i drove the 300 miles to fetch it. I gave you credit of a decent response in your first post and it made me question my stnace with you but you have just fired back in exactly the way you fired back at james about mr tonks car. That again substantiates my thoug thought you didnt give a crap and you are showing it here. Hardly the:
    So me asking your friend to bring the car back so I can take a look wasn't the right thing to do? Spending my private after hours time talking to him on the phone regards it and what happened etc.
    It then never turned up, you bought a second hand engine and fitted it yourselves, that's up to you. I only found this out when afterwards the car came to me with the new owner for some work, that's when I realised it wasn't the original engine.
    If you want to talk, give me a call, that's all I am going to say about the matter, you clearly have a gripe.
    Always been approachable and always will.
    Carl
    Posted 25th Oct 2011 at 23:22
    yippeekayay
    line drawn under.... my point made.
    Posted 25th Oct 2011 at 23:24
    atterz
    Tongue in cheek mate, most definatly a case of internet sarcasm being mis-understood! Has been a legend in regards to this car since ive had it Smile.
    Posted 26th Oct 2011 at 19:25
    b11 bob Banned!
    About time someone on here voiced their opinion about these so called tuners of which most of them only want your money once they get it they not intrested in anything that goes wroung cause they find excuse after excuse to get out of any blame for what they have done to your car
    Yet the many on here continue to praise these tuners and say ive never had any problems with him before.Well if you give me the kind of silly money some of these tuners charge for the work they do to your cars i will make sure you will not have any problems.
    Stop listening and beliving tuner bull***t and find out for yourselfs or use this forum to find answers to your query and do it yourself where possible but beware of these cowboy tuners because there are to many of them around who ONLY WANT YOUR MONEY and when it goes wroung its never is their fault yet some people still continue to fund their so called only earning a living lifestyle wake up and smell the coffee folks
    The above represents my opinion on this please feel free to reply all tuners welcome good ones need not reply the above does not apply to yourselfs
    205 GTI6 235 bhp at 7400 rpm
    Posted 31st Oct 2011 at 00:59
    What just happened?!
    I suspect this thread should probably just be locked before it turns into "one of those".
    Posted 31st Oct 2011 at 07:46
