Author Subject: 45mm Jenvey Bodies/Colin Satchell Inlet for MI16/S16 & GTI6
cjslator
Price missing.
Posted 19th Oct 2011 at 10:53
was there when I read it earlier Unsure
Posted 19th Oct 2011 at 11:23
cwspellowe
Same here, sure it said about £750 for the lot?
Bye bye Sundance Kid Sad
Posted 19th Oct 2011 at 11:24
£700 delivered was the price to begin with
Posted 19th Oct 2011 at 11:52
craig_007
Having a few problems, My post has vanished !!
Anyway here it is again !!!
I'm selling my jenvey bodies and inlet manifold.
The inlet is split new. Below is what I'm selling.
45mm Jenvey throttle bodies complete with fuel rail, TPS and Linkage.
70mm Trumpets
GTI 6 Injectors
Colin Satchell Inlet Manifold (This is longer and gives a better angle than what jenvey/Longman have to offer) This manifold also connects the bodies upside down so gives a better inlet tract.
Also with the above set up you have the option to run 8 injectors. I run the injectors in the original position and have blanked the injector holes in the bodies.
The inlet manifold will come complete with fuel rail and regulator and GTI 6 injectors, I will also supply the fuel rail for the Jenvey bodies. The bodies have been balanced and throttle pot set up so if you have an ECU these are good to bolt on and go.
These are mounted to my MI 16 in my 205, The total inlet length is 400mm from trumpet face to valve face.
I'll do the lot including delivery for £700
Posted 19th Oct 2011 at 16:59
167gti6.
Maybe interested how much use have they have ? and is it everything apart from ecu?
Built not bought!
73k
Diablo ph2.5
Posted 20th Oct 2011 at 18:23
rallye1999
Any pics?
Posted 20th Oct 2011 at 19:15
rallye1999
Any pics?
Posted 20th Oct 2011 at 19:35
craig_007
I bought them off someone else so can't comment on how much use. I personally have done very little with them and as I say the inlet manifold is new.
Everything is there apart from the ecu.
Posted 21st Oct 2011 at 09:56
craig_007
I did have pics up originally. Try again
Posted 21st Oct 2011 at 09:57
no filter?
Posted 21st Oct 2011 at 10:09
craig_007
Nope
Posted 21st Oct 2011 at 12:32
monkeyman
Could you map a standard ecu for use with these, or do you have to have an aftermarket one?
Forum Search Clicky
Posted 21st Oct 2011 at 14:16
craig_007
I've got an after market ecu.
I'm led to believe you can map the GTI6 ECU, Some one on here might be able to point you in the right direction.
Posted 21st Oct 2011 at 15:14
gtisid
wayne at chipwizards rochdale can do this, probably the only guy that can map a gti6 ecu
pugless
Phase 1 GTI 6 1996-1997
Subaru Impreza GB270 2007-2008
rare spiderman comics
same day international courier
Posted 21st Oct 2011 at 21:30
monkeyman
More questions from the noob to tb's.
Could I just swap these, connect fuel and throttle cable, and run on the standard map up to Rochdale, or do they require extensive setting up from the start.
Are 45's more for power and 40's more for torque?
Any ideas on power/ torque increase with/without mapping.
I know people add new cams to a tb setup, will this release much more from them.
How long is a piece of string?
Mines just a fast road car, so Im really looking to increase mid range torque, but I do love the sound of tbs. This is how mine sounds with induction atm http://youtu.be/wg0USySVKX8
Forum Search Clicky
Posted 22nd Oct 2011 at 10:35
rallyeash
Yes there is no real reason why it couldnt be mapped on a stanard ecu, the main problem i can see is the wiring side.
309 3dr K20 Type R
Posted 22nd Oct 2011 at 10:45
matty_rallye
Can the standard ecu run with no map sensor?
2.1 16v 306 Rallye.
Posted 22nd Oct 2011 at 12:05
yup
Posted 22nd Oct 2011 at 16:10
marksorrento205
I recently spoke with Wayne at Chip Wizzards and he said to me its not a problem mapping a std gti6 ecu to run t/b's Smile
Posted 22nd Oct 2011 at 16:41
craig_007
Here's a few pics with them removed from the car.
Posted 23rd Oct 2011 at 00:47
craig_007
Had a re think on price.
I'll do this lot for £650
Posted 23rd Oct 2011 at 00:53
167gti6.
would you do 650 posted?
Built not bought!
73k
Diablo ph2.5
Posted 23rd Oct 2011 at 17:01
craig_007
I would do mate.
Posted 23rd Oct 2011 at 17:31
rallyeash
£600 posted and send the monies over straight away???
309 3dr K20 Type R
Posted 23rd Oct 2011 at 21:46
