Author Subject: Please diagnose my noise!
eddiebeano
Hi all, just recently noticed a noise when going over severe speed bumps with both wheels. It sounds exactly like this:
http://www.youtube.com/watch?v=w0TteLquAkg
any ideas?
Ed
team: Stealth Ninja
Posted 17th Oct 2011 at 23:30
cwspellowe
Is it a creak or a bang?
Bye bye Sundance Kid Sad
Posted 17th Oct 2011 at 23:41
eddiebeano
its like a grating sort of creak. there's no noise when going over a bump with one wheel though, on either side.
team: Stealth Ninja
Posted 17th Oct 2011 at 23:56
eddiebeano
from other forums, it sounds like it could be anti roll bar bushes?
team: Stealth Ninja
Posted 18th Oct 2011 at 00:07
greenbelt
Droplinks Wink
Standard Black 6
Black HBSC6 Smoke
Posted 18th Oct 2011 at 00:16
eddiebeano
i thought that would make more of a bang would it not?
team: Stealth Ninja
Posted 18th Oct 2011 at 00:26
cwspellowe
Aye drop links would be more of a bang.
Does it creak at all when turning the wheel? If yes, top mount bearings. If no...
ARB bushes possibly. Have you got tools to get under the car and disconnect the drop links? If so, disconnect them both and see if it still does it. If it stops you know the problem's one of the two. As said though there's nothing to really creak on drop links. Bearings or bushes creak though, just a bit stumped as to what would cause it if its only when both sides bump over something.
Posted 18th Oct 2011 at 00:33
I'd check the arb bushes and that the clamps are located properly in the slots on the subframe.
Posted 18th Oct 2011 at 00:38
eddiebeano
not a squeek from the steering lock to lock. I'm pretty sure I need new drop links anyway, but this is a new noise. I should have the tools to disconnect them, but I may as well change them at the same time I think. It almost sounds like someone cutting bendy plastic with a jack saw if you can imagine it!
team: Stealth Ninja
Posted 18th Oct 2011 at 00:41
eddiebeano
It's gone away now anyway, so I guess I won't find out.
team: Stealth Ninja
Posted 21st Oct 2011 at 23:32
