Author Subject: Huge water leak
306crazy
Right my fans stay on after the engine is turned off and they even kick in when the ignition is turned but not started. Now ive got a massive water leak coming fron below the the engine,ive disconected the battery now and the water has stopped coming out. Whats wrong with it ?? Thank you
Posted 14th Oct 2011 at 18:01
blue_haddock
You've got a water leak!
suck my plums!
Posted 14th Oct 2011 at 18:14
Sounds like either a f*cked rad or a f*cked waterpump.
Just pray its the first
306crazy
Cheers rat Thumbs up hopefully it's just a pipe though
Posted 14th Oct 2011 at 19:08
Reconnect the battery and see if the water starts leaking again.
Posted 14th Oct 2011 at 19:10
mattgti6phase2
Check the hose that goes into the water jacket. The pipe could have perished or the clip may have come away. Other than that I agree with the above as regards to the water pump.
As for your fans running with just the ignition on that's due to the car being so hot or turning your engine off at the point the fans naturally come on.
Team Nile 6 Superman
Team: 40.2 MPG Smile
5 x a 306 owner!
I truely live for the 306 ®
midweek madness Tee hee
Posted 14th Oct 2011 at 19:45
306crazy
No it's not come on 1st thing In the morning it doesn't overheat eitet
Posted 15th Oct 2011 at 16:37
cwspellowe
Probably because the fans are always on Laugh
Sounds like two different faults to me, faulty fans and a coolant leak. Just jack it up and have a look Dunno
Bye bye Sundance Kid Sad
Posted 15th Oct 2011 at 16:55
atterz
Id say waterpump if its cambelt side! Mine did this a couple of weeks ago!
owain wrote:
Posted 15th Oct 2011 at 17:02
306crazy
It's stopped leaking now :S very odd indeed!
Posted 15th Oct 2011 at 23:53
BrianM
put more coolant in to see if it does the same thing to see if you've not just run out of water as well! Hence you'll be able to see if the added pressure makes a difference to the leak and you'll be able to pin point the problem better?
'13 208 Gti Bianca White, '99 Bianca 306 Rallye, '92 309 Goodwood GTi 5dr, '92 Miami Blue 309 GTi 3dr.
Posted 16th Oct 2011 at 00:52
306crazy
Taking it to be checked out to tomorrow getting new discs and pads aswell so get it checked aswel
Posted 16th Oct 2011 at 16:37
