Author Subject: standard six brakes and brembo threads?
russbez
trying to pop a piston out on a fairly stuck gti6 caliper - using compressed air, got one out... this one wont budge
anyone know off the top of their head if the hoses are the same thread as brembo braided hoses?
planning using Rallye to pop piston out on this old caliper
then rebleed brembos on rallye job done
Thanks
My Rallye project thread
Posted 7th Oct 2011 at 15:32
usually are normal M10, try pushing it in first, it may not be quite straight.
Posted 7th Oct 2011 at 15:39
russbez
tried tapping the piston all directions with plastic mallet
squashed piston back in
WD40 everywhere, overnight been trying last two nights
piston in and out a few times wont come out past that last 10mm
can see that the internal seal is buldging out as if its not seated in place correctly
new seal kit coming but still need this f*cker out
anyone know if threads are same?
Posted 7th Oct 2011 at 16:08
mark.evs
I dunno if they'll be the same where they meet the caliper but they'll be the same where the hose meets the steel pipe, could swap the caliper and hose onto the car to pop it out.
Or see if you can up the pressure on the air line.
My GTi6 track project
White Rallye project
Posted 7th Oct 2011 at 16:40
Pretty sure all the calipers I've had, Pug and Brembo, are all standard M10 thread. My new ones were siezed, just attached it to the car, put g-clamps over the un-siezed pistons and pushed the pedal, had the piston out in seconds Yes
Posted 7th Oct 2011 at 17:13
russbez
aww forgot about this
they are the same thread, eventually got old piston out, had to bleed brakes and pump them a fair bit to get piston out
gave a a good satisfying spirt of brake fluid as piston came out LOL
Posted 18th Oct 2011 at 16:20
Stripping all your paint in the process Yes
Posted 18th Oct 2011 at 16:22
russbez
got shotblasted
Posted 18th Oct 2011 at 16:44
I find it usually strips all the skin around your eyes whilst you running around screaming for water Yes
Posted 18th Oct 2011 at 16:46
monkeyman
"gave a a good satisfying spirt of brake fluid as piston came out LOL"
Rule 34 Yes
Forum Search Clicky
Posted 18th Oct 2011 at 17:40
