Author Subject: Low boost hesitation/misfire
On my way to work this morning, started the car, drove to the end of my street and turned left at the T-junction and headed off uphill, I got into 3rd and was pootling along at about 25 letting it all warm up and it started to struggle and hold back is the only way I can think to describe it. AFR was well up arount 17-19 but it seems to be like that quite a lot at low engine loads or trailing throttle so I was'ntoverly concerned. The journey to work is short and with rush-hour traffic I never gotthe chance to strech her legs and see if it cleared or not. If I had a plug/ coil-pack failing I would guess I would get a similar symptom but see a richer mix if I was getting no spark on one cylinder as it would just be blowning through unburnt fuel down one pot. This leads me to think dodgy/blocked injector? Anyone experienced anything similar to this?
Posted 7th Oct 2011 at 14:42
simonjames
Mine was doing doing this, hesitant under load to start then came undrivable, i changed loads of things untill i changed the pump to find a blocked pick up
MY EBAY ITEMS
07943066306
Posted 7th Oct 2011 at 15:02
rich_w
You got an AEM wideband AFR gauge / controller Jim?
These have been known to cause issues as described when in the narrowband lambda simulation mode.
It's also worth checking the lambda sensor is OK if you don't have the wideband.
Contact Details:
07732 822546
Posted 7th Oct 2011 at 15:39
I have the AEM guage and sensor, not sure what spec the rest of the system is with regards to the original lambda and fuel pump. The injectors don't look original, they are green but not the dull olive green you get normally, more like a bright Kawasaki green if that makes any sense?
Posted 7th Oct 2011 at 16:22
rich_w
Yeah they are Bosch 020 150 558 440cc injectors and the right ones for the job.
I doubt they are at fault.
The problem is more likely to be electronic, possibly down to the wideband simulation of the narrowband sensor, or the lambda sensor itself, or another compensation table that affects fuelling like the CTS.
Does it do it when hot?
Contact Details:
07732 822546
Posted 7th Oct 2011 at 16:29
First time its done it at all, and it was from stone cold.
Posted 7th Oct 2011 at 17:30
mcfc1987
Never done that before and the car runs off the standard lambda, the aem is in a second boss and runs completely separately everything else. its just for show
Posted 7th Oct 2011 at 18:06
mabgti
NV motors
Wise move as thats how i run mine..
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 7th Oct 2011 at 19:36
mabgti
NV motors
My guess is the fuel pump with starvation uphill.. or injector wiring.. sometimes the dipstick can chafe as its squeezed tight against the plenum.
NV Motorsport
0121 448 7515
Facebook Page
Project S6
Posted 7th Oct 2011 at 19:38
I think youve been stung and bought a lemon Wink
Posted 7th Oct 2011 at 22:00
+1 Thumbs down
Posted 9th Oct 2011 at 12:00
Now you mention it the fuel pump does seem to prime all by itself a few times after is switch off an get out. I don't remember it ever doing that before.
Posted 9th Oct 2011 at 12:02
smegal
Take it to someone who has a diagnostics machine. I'd do it if I wasn't at the other end of the country.
Ex SC-6
Now in a Megane R26
Posted 9th Oct 2011 at 14:37
Rich W is taking a look this coming Saturday. It's not a lemon I just keep seeing lots of little jobs that need doing soon to stop it slipping into bieng a bit of a millstone. The thing I'm most bothered about is the fact that one front wheel has zero camber and the other has negative, so from experience it's got a bent hub carrier , shock, mis-aligned sub-frame or a combination of all three. Hopefully its just biffed a kerb a bit hard and shifted the subframe over a little as the boltholes have about 3mm of clearance to help setup the geometry.
Posted 9th Oct 2011 at 20:08
could be a non-pas balljoint, they are shorter.
Posted 9th Oct 2011 at 20:11
Cheers Mei, I'll have alook at that this weekend, hopefully that will sort the twitchy handling as it's not very confidence inspiring at the moment.
Posted 10th Oct 2011 at 10:25
does the speedo work btw?
Posted 10th Oct 2011 at 11:44
can the front subframe reeally be pushed
Forward a
Few mm?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Forward a
Few mm?
Certainly, it's only held in place by six bolts and they have about 3mm of clearance on the holes, you normally find something else bends first though as I found out to my cost when I clouted a kerb in the snow. They often don't get put back exactly as they were so if they get removed for any reason get the tracking chercked over.
Posted 10th Oct 2011 at 12:37
Just incase anyone is interested or has the same problem, I removed the plastic cover which goes over the coilpacks with a view to checking/replacing the plugs. What I found was that the coil pack on cylinder two was held loosely in place by one bolt, the other had the head broken clean off and the sparkplug beneath it was rattling around loose, the other three weren't that tight either. I replaced all four plugs even though they looked perfect and refittef the coilpacks with a new bolt and no hesitation has shown up since.
The car has also been rolling roaded to get the info on air/fuel ratio for peace of mind and it's running at a pretty safe 12.5:1 at WOT under hard load. The AEM guage is hopelessly out though so I need to contact them and see what can be done to reconfigure it to be more useful. Power was slightly down on what I expected at 235 BHP but I discovered and fixed the loose plug/coil after it hit the rollers so thet may have been a factor.
Posted 30th Oct 2011 at 23:46
ballardpaul
Mine hesitates when cold, but i believe im the only one using the wideband lambda as the one for the car. I changed the setting to P03 and it doesnt do it anymore.
Maybe if you change the setting it will be more accurate?
Need to get Rich to look at it one day but the journey puts me off LOL
Nissan 350Z (300 BHP)
Posted 31st Oct 2011 at 00:23
I'll have a look at downloading a manual from Google, see if that makes it any better, cheers.
Posted 31st Oct 2011 at 10:23
http://www.schnitzracing.com/manuals/AEMWBK.pdf
How do you know its out btw?
Posted 31st Oct 2011 at 11:07
Thanks Mei, I know the rolling road used a very expensive Dyno Dynamics AFR probe with a very new calibrated NGK lambda sensor on it. That and the fact the engine would've expired long ago if it was actually running at the AFR the guage indicates tells me something is'nt adding up Wink
Posted 31st Oct 2011 at 12:08
