Author Subject: the AA
mcfc1987
yes another annoying thread by me... sorry, last one i promise
i am a member of the AA through my bank, if i ring them and explain i have an oil leak will they come and recover the car to the garage that did the work earlier today and may have caused the leak?
Posted 5th Oct 2011 at 21:24
jord294
doubt it
Posted 5th Oct 2011 at 21:30
gman
I think they take it to the nearest, within reason.
1992 Onyx Black 205 GTI-6
2005 Honda S2000 (Sold)
2002 Audi S3 (Sold)
2005 Clio 182 Trophy (sold)
Posted 5th Oct 2011 at 21:32
mcfc1987
Ball bags
Posted 5th Oct 2011 at 21:36
cappy01
they will only recover if the car is un drivable or not safe to do so
Posted 5th Oct 2011 at 21:39
musclebeach
Had this the other day, i had basic cover which meant they'd recover me to the nearest garage or home whichever was closer.........guy very kindly agreed to recover it to my house which was 12 miles away.........i gave him a tenner for his troubles. Usually he'd just drop it off at the nearest garage.
Hope that helps
VW Golf GT TDI 115, 100k nooooooooooooooooooooo!
Posted 5th Oct 2011 at 21:42
cwspellowe
Unplug something in the engine bay near the oil leak. When he has a look, point out that you can see oil and can he just check it pretty please?
Bye bye Sundance Kid Sad
Posted 5th Oct 2011 at 21:44
mcfc1987
Sod it, ill have a quick look in the morning in daylight then probably just get Carl to come and get it. just what i bloody needed!
Posted 5th Oct 2011 at 21:48
720puggti
Dan I'm a little confused...
In the thread "right..." you stated, and I am quoting:
"i decided to nip it to a recommended garage 1 minute walk away to have the wheel bearing changed as i just couldnt be bothered to do it myself"
Surely if you think you're capable of changing a wheel bearing, you can jack the car up and check to see if the hockey sticks holding the driveshaft are loose, can't you? If they are, they simply require retightening and the gearbox oil replacing.
I think you're making this more than it needs to be.
Deepak Gohil
Posted 5th Oct 2011 at 22:17
mcfc1987
Yeah i plan on having another poke around in the morning but i am planning for a worst case.scenario where.i can't find anything obvious
Posted 5th Oct 2011 at 22:28
