displaying posts 1 to 25 of 50
Author Subject: My Wheels
techdw
Would like your guys input on this please, One wheel looks like its in more then the other, will check the offset of the wheels but they are ET15.
Is it my eyes or does it look different?
Posted 4th Oct 2011 at 14:20
Hard to tell and might be the camera angle, but looks like the second one might have a bit more camber, which would be due to a collapsed bearing.
I'd double-check the offset (what they're stamped with and measure them yourself) then check the camber.
Posted 4th Oct 2011 at 14:26
i think you should get rid of them wheels immediately
to me
Posted 4th Oct 2011 at 14:28
techdw
I am going to take the wheels off and double check later mate.
Is the Camber ajustable on the rear?
mr west
if it has negative camber on one wheel at the back it will be a trailing arm shaft bearing collapses as
owain said, but they look pretty good to me, hard to tell from pics
white rallye
cherry dead rallye
s16
Posted 4th Oct 2011 at 14:53
techdw
RIGHT wheel Rear
Left Wheel Rear
Posted 4th Oct 2011 at 15:14
techdw
Left Looks bent!??
Posted 4th Oct 2011 at 15:15
yup, I'd get a new beam, likely to have slid against a kerb at some point in its life.
Posted 4th Oct 2011 at 15:39
techdw
What cost am i looking at for a new beam?
Posted 4th Oct 2011 at 15:46
depends how far you go, could be as little as £40 or so if you use your torsion bars and brakes and you just chuck it on and hope, or £150-£200 if you rebuild it whilst its off.
*if you do the work yourself, its not hard but you will often need access to a press and often proper heat (oxy-prop/acetylene)
Posted 4th Oct 2011 at 15:52
2nd hand unit with a bit of life left it in, £100-£120 with calipers.
Chances are it could go the same way in time.
Refurbed beams are a few hundred, but will have nwe bearings etc so will last
  • Posted 4th Oct 2011 at 15:52
    mark.evs
    U got a pic of the back of the car with both wheels in it? they look the same to me but the gap in the arch is making it look out. beams are anything from £100-£500.
    My GTi6 track project
    White Rallye project
    Posted 4th Oct 2011 at 15:53
    I'd take it somewhere and get them to measure the rear tracking, should be zero both sides.
    Posted 4th Oct 2011 at 15:58
    techdw
    Posted 4th Oct 2011 at 16:03
    mark.evs
    Really hard to tell, if it is out it aint by much, like Owain said, get it 4 wheel aligned.
    Posted 4th Oct 2011 at 16:08
    techdw
    Yeah will have to get that checked.
    Posted 4th Oct 2011 at 16:09
    ballardpaul
    Look identical to each other.
    Nissan 350Z (300 BHP)
    Posted 4th Oct 2011 at 16:16
    Jack the car up under the beam in the middle until the tyres lift slightly off the ground and see if they both lift at the same time
  • Posted 4th Oct 2011 at 16:31
    Jack the car completely off the ground and place a chinchilla under each wheel. Lower the car gently and see if they both squeak at the same volume.
    Standard test.
    Posted 4th Oct 2011 at 16:34
    will130787
    Looked exactly like mine did which got progressively worse over time and one side started to 'collapse' after the beam had been 'rebuilt' 10k miles earlier by CG cars. My trailing arm was bent slightly and the beam was fuc*ked! Take the wheels off, check the offset on each and check for movement in each trailing arm! Smile
    Ex Astor 6 owner Sad
    Also an Ex owner of a Bianca 6 Sad
    Now an ex owner of a 2005 9-3 2.0T 210bhp Aero Swedish Saloon thing!! Soon to be 250bhp.... Superman
    Now driving Mk5 Golf GTTdi, mile muncher
    But still live for the 306 Ninja
    Posted 4th Oct 2011 at 21:08
    cwspellowe
    Yes, but not intentionally
    Bye bye Sundance Kid Sad
    Posted 4th Oct 2011 at 21:20
    techdw wrote:
    With the lack of wiper arm, spray paint on the number plate and the saggy hand brake cable these could all cause uneven weight distribution giving the effect of a f*cked car.
    Posted 4th Oct 2011 at 22:23
    mechanical_repairs
    Yet another been rebuilt by carl but this is the first I hear of it!
    When the car was here Wayne it never looked like it had a beam issue. I would say it's best to rebuild now as finding a known good unit will be slim, if you do then you will also have to have the ride height adjusted again.
    Get it checked first, it may be nothing.
    Carl
    Posted 4th Oct 2011 at 23:28
    techdw
    Cheers Carl. Yeah agree with you there mate, it all looked Okay.
    Will Check it first before I do anything.
    Posted 5th Oct 2011 at 07:55
    davewagon
    What size are these alloys, looks good fit ! 15/16 inch?
    Team: Moonstone GTI-6™
    Team: Working air-con™
    ian7675 wrote:
    Posted 5th Oct 2011 at 13:31
