Bolt going into the slider kindly snapped in half and half of it is still in the slider
| Author | Subject: HELP Please! |
honestly3k
Seasoned Pro Location: Berkhamsted Registered: 06 Apr 2009 Posts: 2,390 Status: Offline |
Dont suppose anyone has a front caliper carrier sliding pin with bolt close to Tring, herts and can help me out?!?!?!Bolt going into the slider kindly snapped in half and half of it is still in the slider ![]() ________________________________________ ''Oh, it does handle like a golf!'' Why drive a Golf....when you can drive a GTi-6? |
6waysforward
Seasoned Pro Location: Benfleet essex Registered: 30 Oct 2005 Posts: 3,168 Status: Offline |
local scrappy mate. iirc you can use the sliders from a 406 with the same size discs or failing that, a xsara or 306 etc.________________________________________ ***Breaking*** Ph3 Silver GTI 6 High Boost![]() |
if there's a bit protruding you should be able to wind it out with some grips.90% or so of 406's uses the same caliper btw. ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
I managed to get one out the other day by twatting it with a hammer back and forth until it came loose ![]() ________________________________________ Membership expiring soon, get in contact on our new little forum project. |
honestly3k
Have no transport to get to a5 salvage about 12 miles away. Found a bolt I can use but getting the half bolt out of slider isn't going well.....there's barely any thread protruding ![]() ________________________________________ ''Oh, it does handle like a golf!'' Why drive a Golf....when you can drive a GTi-6? |
Stick another bolt in and hammer the old one out?________________________________________ Membership expiring soon, get in contact on our new little forum project. |
drill it oot ![]() ________________________________________ need a part number? get on here - http://public.servicebox.peugeot.comBring on the Trumpets. |
honestly3k
Drilling it out slowly...drill is low on battery lol.....got the small hole drilled.....I'm a tard...just found out I only needed to undo the carrier and not calipers anyway to get to the disc and pads. ![]() ________________________________________ ''Oh, it does handle like a golf!'' Why drive a Golf....when you can drive a GTi-6? |
honestly3k
Sorted! Drill ftw! Lesson learnt....thanks boys________________________________________ ''Oh, it does handle like a golf!'' Why drive a Golf....when you can drive a GTi-6? |
