Author Subject: Strange clocks/instruments failure? :S
adiesouthwell
Hi all Smile
Ok, battery on my 6 was changed, speedo and odometer/digital part stopped working!!!
The rev counter is fine and so are the other gauges, temp/fuel etc.
Just the speedo and digital.
The digital screen is still lit up and the mileage is showing but its not clocking trip miles.
Any fabulous life saving ideas?
Thanks in advance Guys. Thumbs up
OMP Strut Brace
3" Stainless scorpian
Remap
Superchipped
R.A.M Air Kit
Running 170Bhp @ 6500rpm with cert Smile
www.gti6forum.co.uk
Posted 26th Sep 2011 at 20:58
6waysforward
The speed sensor located on the top of the gearbox could have been knocked by the sounds of it. It is unlikey if only the battery was changed but thats what mine did when the sensor took a knock.
Posted 26th Sep 2011 at 21:09
adiesouthwell
where abouts will i find the speed sensor?
Anyone got a pointy?
Thanks Smile
OMP Strut Brace
Remap
Superchipped
R.A.M Air Kit
www.gti6forum.co.uk
Posted 26th Sep 2011 at 21:24
mike rallye
it is located on the back of the gearbox. you should be able to see it from the top of the engine,
Posted 26th Sep 2011 at 22:14
mechanical_repairs
Pull the shunt fuse (odd looking fuse in the fusebox under the steering wheel) and re insert, that will sort it.
Carl
Posted 26th Sep 2011 at 22:53
adiesouthwell
Carl, if you are correct, I am not worthy lol thanks Smile
OMP Strut Brace
Remap
Superchipped
R.A.M Air Kit
www.gti6forum.co.uk
Posted 26th Sep 2011 at 23:11
adiesouthwell
Hmm what are you calling odd looking carl?
Its the 30 fuse box.
Thanks.
OMP Strut Brace
Remap
Superchipped
R.A.M Air Kit
www.gti6forum.co.uk
Posted 27th Sep 2011 at 17:31
grumpychef
The Rib Man
Thanks.
isn't the shunt fuse the big silver one in or near the middle of the fuse box under dash?
Formally team BLAZE now Team bianca recuperating from multiple organ failure nicely!
items replaced so far, clutch, cambelt etc, radiator, exhaust, most of front running gear, wish bones, drop links, ball joints, track rod ends, bearings, brakes, calipers, discs, and pads, brake lines, front springs, brake balance compensator thingy, hand brake cable, throttle cable (twice), coil pack, door handle, windscreen, wipers, head lamps several sensors and bulbs Dry .rear beam new throttle cable, new battery. .......... yeah man, team money pit! but shes still rollin!
Posted 27th Sep 2011 at 18:09
monkeyman
Yeah thats the one, solid metal fuse bar.
Forum Search Clicky
Posted 27th Sep 2011 at 19:50
adiesouthwell
Ah will try that tomorrow then thanks Smile
OMP Strut Brace
Remap
Superchipped
R.A.M Air Kit
www.gti6forum.co.uk
Posted 27th Sep 2011 at 22:05
Lecktorious
aka G.
There's a FAQ on this Wink
'98 Nile Blue 306 GTi 6
Posted 27th Sep 2011 at 22:17
adiesouthwell
WHereee? i looked everywhere for a report of this problem before.
Anyway, i found that fuse and removed it with no luck Sad
Had the battery off completely to see if i could see any problems also with no luck Sad
Did the reset proceedure when the battery was back on with no result..
Any more ideas?
Thanks.
OMP Strut Brace
Remap
Superchipped
R.A.M Air Kit
www.gti6forum.co.uk
Posted 28th Sep 2011 at 19:34
adiesouthwell
Does anyone have a pointy for the speed sensor?
Im guessing its a transducer?
thanks.
OMP Strut Brace
Remap
Superchipped
R.A.M Air Kit
www.gti6forum.co.uk
Posted 28th Sep 2011 at 19:51
adiesouthwell
Think i may have found the transducer, would it be on the gearbox just behind the thermostat?
OMP Strut Brace
Remap
Superchipped
R.A.M Air Kit
www.gti6forum.co.uk
Posted 29th Sep 2011 at 16:50
kinda yeah, 3 pin white sensor on the r/h driveshaft side
Posted 29th Sep 2011 at 17:11
adiesouthwell
right hand side? as in the drivers side or right hand looking under the bonnet lol?
OMP Strut Brace
Remap
Superchipped
R.A.M Air Kit
www.gti6forum.co.uk
Posted 29th Sep 2011 at 17:21
greenbelt
From under the car follow the path of the drivers side driveshaft and it is above where it enters the diff. It should be in a silver coloured pouchy type thing Wink
Standard Black 6
Black HBSC6 Smoke
Posted 29th Sep 2011 at 17:29
adiesouthwell
Ok it seems to be clean and in tact, does it just need replacing or is there something else i can do?
Thanks.
OMP Strut Brace
Remap
Superchipped
R.A.M Air Kit
www.gti6forum.co.uk
Posted 30th Sep 2011 at 17:18
