Author Subject: Acceptable AFR on Lynx low boost SC
judley
Hi guys, just setting the 205 up on the dyno and we are seeing AFRs of 13.5 when on boost. Is 13.5 going to run it too lean and risk det or is it within normal safe parameters?
Posted 26th Sep 2011 at 19:33
rich_w
At what point in the rev range is that AFR?
What exhaust / intercooler do you have?
What fuel pump are you running?
Smile
Contact Details:
07732 822546
Posted 26th Sep 2011 at 20:30
smegal
13.5 is rich, not lean.
Ex SC-6
Now in a Megane R26
Posted 26th Sep 2011 at 20:51
smegal wrote:
13.5 is rich not lean.
It's rich of stoich, but it's not necessarily rich for a boosted engine map....Thumbs up
Posted 26th Sep 2011 at 20:53
judley
Smile
Thanks for getting back to me Rich, you can ignore that text I sent you earlier ;-)
The AFR is flat from 2,000 RPM all the way to the redline.
Exhaust is 2" Magnex decat
Standard fuel pump
Unbranded IC as the high boost IC was too large. The IC felt cool after the dyno run though
ECU is your low boost one {bought from birk} and is I believe a later version with better idle control?
Injectors are the 440cc ones I got from you a couple of weeks back
What do you reckon mate?
Posted 26th Sep 2011 at 21:01
smegal
You'll find that it is only like that on full throttle. On part throttle at constant speeds mine hovers round 14.7 ish.
Ex SC-6
Now in a Megane R26
Posted 26th Sep 2011 at 21:52
judley
Shouldn't it be around 11 or 12 though?
Posted 26th Sep 2011 at 22:06
judley
judley
rich_w
You want it to be around 12.5.
To richen yours up, I would check your fuel pressure isn't dropping off at the top end, if that's OK I can supply a slightly smaller restrictor which will richen it up.
Intercooler and exhaust choice are the main things that will affect the AFR on our conversion.
13 is not dangerously lean - so don't worry too much.
Make sure you use V Power too Smile
Contact Details:
07732 822546
Posted 26th Sep 2011 at 22:30
judley
Thanks Rich. Can you PM me a price for the restrictor please.
Posted 26th Sep 2011 at 22:49
Does a bigger a/c make it richer or leaner?
andrew315rawson@live.co.uk
Moonstone phase 7 gti6
Posted 5th Oct 2011 at 18:45
Leaner
Posted 6th Oct 2011 at 10:28
Need to check mine, its regularly in the 14's
Posted 6th Oct 2011 at 10:31
mabgti
NV motors
Dave you'll need to get that checked. Just double check the sparkplugs are cooler and that you have no leaks on the exhaust side of things.
Team Supercharged Gti-6
NV Motorsport
Automotive Performance Tuning
0121 448 7515
ECU Remapping/ DPF removal
www.nvmotorsport.com
Facebook Page
Project S6
Posted 6th Oct 2011 at 11:21
Will do, I've got Rich W giving it the once over soon but I'm driving it off boost until he can give it the ok.
Posted 6th Oct 2011 at 14:36
What number spark plugs should they be by the way? Looks like I only just missed out on a f*cked Rotrex, the traction fluid was nearly all gone from the reservoir, an inch below the minimum so I'll be investigating the pipework for leaks this weekend.
Posted 6th Oct 2011 at 14:39
ballardpaul
I believe 7s are the ones you want Hmm
Nissan 350Z (300 BHP)
Posted 6th Oct 2011 at 15:42
rich_w
You want the 7s or 8s for low boost, depending of the nature of use.
The plugs will not affect the air fuel ratio in anyway, but play an important part in heat management.
Contact Details:
07732 822546
Posted 6th Oct 2011 at 16:12
Higher the number the hotter they get, correct?
Posted 6th Oct 2011 at 16:38
chris with a pug
Depends on the make IIRC
Posted 6th Oct 2011 at 16:56
If they're NGK's the higher the number the cooler they run, with Bosch it's the other way around.
Posted 6th Oct 2011 at 17:15
