displaying posts 1 to 2 of 2
Author Subject: JVC KD_AVX1 DVD Head Unit
pugjim
Spec
MP3/WMA Compatible with ID3 Tag/WMA Tag
Yes
CD-R/RW Compatible
Yes
CD Text
Yes
Disc Name Registration
Yes
Direct Track Access
Yes (with remote control)
Intro Scan
Yes
Random/Repeat Play
Yes
DVD Player
KD-AVX1
Video DAC
10-bit/54MHz DAC
Video Format
NTSC
DTS/Dolby Digital/MPEG Audio
Yes
Shock Proof Memory
Yes
Direct Chapter Access
Dual-Zone Function
Yes
Pause/Step/Slow
Zoom
Frequency Response
16 - 22,000Hz (DVD fs=48/96kHz), 16 - 20,000Hz (CD)
Dynamic Range
93dB (fs=48kHz)
Channel Separation
85dB (at 1kHz, fs=48kHz)
Signal-to-Noise Ratio
95dB (fs=48kHz)
Wow & Flutter
Less than measurable limit
VCD Player
KD-AVX1
Video Format
NTSC
Video CD Playback Control
Yes
Direct Track Access
Pause
Step
Slow
CD Changer Control
KD-AVX1
MP3 Control
Yes (with CH-X1500)
CD Text
Yes (with CH-X1500)
Yes
Intro Scan
Yes
Random/Repeat Play
Yes
Radio Tuner
KD-AVX1
SIRIUS Ready
Yes
Tuner Type
HS-IIIi
Yes
Preset Stations
18 FM, 6 AM
SSM (for FM)
Yes
AFNS/PNC
Yes
Seek (Up/Down)
Yes
Stereo/Mono Switch (for FM)
Yes
TV Tuner Option
Yes
Auto Antenna
Yes
European Switchable Tuner
Yes
FM
Frequency Range
87.5 - 107.9MHz
Usable Sensitivity
11.3dBf (1.0uV/75 ohms)
50dB Quieting Sensitivity
16.3dBf (1.8uV/75 ohms)
Stereo Separation
35dB
Capture Ratio
1.5dB
AM
Frequency Range
530 - 1,710kHz
Sensitivity
20uV
Selectivity
35dB
Amplifier
KD-AVX1
Maximum Power Output
50W x 4
Continuous Power Output (RMS)
20W RMS x 4 Channels at 4 ohms and no more than 1.0% total harmonic distortion + N
MOS-FET Amplifier
Yes
Audio DAC
96kHz/24-bit DAC
Source-Specific Volume Control
Yes
Volume Attenuator
Yes
Balance/Fader Control
Yes
Equalizer
7-Band iEQ
Yes
Max. Amp Gain Switcher
Yes
Amp Defeat Switch
Yes
AV Input Terminals (Video + L/R)
Yes (Gold-plated)
Line Output Terminals (pair)
2 Pairs (Gold-plated)
Second Audio Output Terminals
Yes (Gold-plated)
Subwoofer Output with Level/Frequency Control
Yes (Gold-plated)
Optical Digital Output
Yes
Frequency Response
40 - 20,000Hz
Load Impedance
4 ohms (4 - 8 ohms allowable)
Pre-output level/impedance
2.0V/1k ohms
Video Output Level/Impedance
1.0Vp-p/75 ohms
Audio Output Level/Impedance
2.0Vrms/1k ohms
Video Input Level/Impedance
1.0Vp-p/75 ohms
Audio Input Level/Impedance
1.5Vrms/20k ohms
Monitor
KD-AVX1
Screen Size
3 Inch
Angle Adjustment
Yes
Screen Resolution
186 x 220 x 3
LCD Type
TFT Active Matrix LCD with Wide Viewing Angle
Color System
NTSC
Display
KD-AVX1
Switchable Dimmer
Yes
Power Switch Standby Illumination
Yes
General
KD-AVX1
Face Type
Motorized Slide-Out Face
Yes
Detachable Face Panel with Carrying Case
Yes
Steering Remote Control Ready
Yes
Wireless Remote Control Type
Multi-Function Wireless Remote Control
Yes
Beep Tone Support
Yes
COMPU PLAY
Yes
Tel. Muting
Yes
Power-Off Mode Eject
Yes
Dimensions (W x H x D)
Installation Size
182 x 52 x 160mm (7-3/16" x 2-1/16" x 6-5/16"Wink
Panel Size
188 x 58 x 18mm (7-7/16" x 2-5/16" x ¾"Wink
Detachable Face Plate Size
169 x 58 x 24mm (6-11/16" x 2-5/16" x 1"Wink
Missing surround trim and remote. Screen sometimes goes off but you just need to push the front panel and it comes back on and stays on. Looking on google its just the contacts that need cleaning up.
£35 posted
Posted 20th Sep 2011 at 16:54
pugjim
SOLD !
Posted 20th Sep 2011 at 18:05
