Author Subject: timing belt advice
mike rallye
hi guys, am after some advice and help.
A few weeks ago i noticed that my timing belt had started to shread it self on the out edge,the belt had only done about 30,000miles.so i replaced the timing pinon as this is the only part i never replaced and fitted another new belt. anyway i decided to re check the belt today and it has ever so slightly started to shread, i havent a clue why this is happening so am after some help and ideas?
there is few pictures in my project thread of the old belt.
parts that are new are
waterpump
cambelt kit
timing pinon
mike
Posted 19th Sep 2011 at 20:56
matt_gti
Is it shredding on the inner or outer part of the belt as it may be a bit of the timing belt covers that it is catching.
306 GTI-6
205 GTI-6 Project
205 1.6 GTI - RIP
205 1.9 TT - RIP
E39 535i - Daily driver
*Newest edition* E60 M5 5l v10 - The weekend car Smile
Posted 19th Sep 2011 at 22:47
incorrect tension ???
Posted 19th Sep 2011 at 22:57
720puggti
Hi Mike,
I had a look at your project thread, that belt didn't look good.
My first question is, which way was the belt fitted? Because, if it's fitted back to front it can migrate.
Second, did you put extra sealant around the waterpump when fitting it? Because if it is sitting cocked then that too can cause the belt to migrate.
Deepak Gohil
Posted 20th Sep 2011 at 14:44
mike rallye
matt gti- the belt was shreadded on the outer part of the belt
bigbadbowen- as far as amaware it thr right tensioner,unless the one i previous had was incorrect.
720puggti- i fitted the timing in the anticlockwise way,and yes i did fit a little bit of extra sealant on water pump. could this be the problem and how the best way to find out.by removing it?
Posted 20th Sep 2011 at 19:05
mike rallye
here few pictures
Posted 20th Sep 2011 at 19:09
if that belt has only been on a few weeks then its likely to be way too tight!
Posted 20th Sep 2011 at 19:23
mike rallye
the belt in the picture is the old belt i took off, not the new one
Posted 20th Sep 2011 at 19:50
720puggti
Hi Mike,
I meant was the belt fitted in the correct direction of of rotation? I.e. if the belt has arrows printed on it, was it fitted so the belt rotated in the direction of the arrows as the engine ran?
If there were no arrows, then you use the printed words (Dayco, Gates, Contitech etc) so that they're facing you as you fit the belt while leaning over the wing. I.e. you should be able to read the words as you fit the belt and they're not upside down.
A sure fire way of knowing whether the belt is too tight is if it has a high pitch whine when the engine is running.
If I were you I would start with a new belt, mounted and tensioned correctly and a clean faced waterpump with only the gasket fitted. While you're there, check the tensioner and roller a running true by spinning them up by hand.
Good luck mate!
Deepak Gohil
Posted 20th Sep 2011 at 21:41
mike rallye
the belt didnt have any arrows on it, and the belt ran in the same direction as the engine. i havent got no high pitch sound from the belt,i tension it up using a semiens gauge.
ok i will get another kit and water pump and see what happens,what i dont want to do is replace it all and the same still happing. do you think maybe the cam pulleys maybe knackered.i have got the latest ones fitted
Posted 20th Sep 2011 at 22:26
jord294
your welcome to fetch the car to me mate if you'd like me to do it for you Wink
Posted 20th Sep 2011 at 22:44
720puggti
Hello once again Mike,
I don't think you understand what I'm saying. Belts are manufactured to fit on the engine in way only, even though they appear to two ways. It's difficult to describe over the internet like this, especially without pictures as well.
By the way I wouldn't change the whole kit, just the belt; the whole kit is a waste of money, unless the tensioner and roller are broken in some way.
I've never seen knackered cam pulleys, so I doubt it'd be that.
If you're still struggling mate, I suggest you accept Andy's (jord294) offer. The last thing you want is a snapped cambelt.
Deepak Gohil
Posted 21st Sep 2011 at 00:10
Make sure there is'nt a sharp edge now on the rear of the crankshaft pulley as the side of the belt has probably been rubbing on that.
Posted 21st Sep 2011 at 11:41
