Author Subject: Sensors, resonator, badges
cwspellowe
ICV, used but in GWO, £15 posted
TPS, used but in GWO, £12 posted
Inlet manifold helmholtz resonator £7 posted
All removed from a late reg Xsara VTS
Also have three genuine Pug inlet manifold badges, £4 each posted
Bye bye Sundance Kid Sad
Posted 15th Sep 2011 at 11:56
toddy
I can't reply in the engine forum for whatever reason:- Your engine problem most likely feels that the handbrake is on until you reach 1300rpm then the power comes in, this is because the ECU is not receiving a signal from your VSS to tell it that the car is now moving and not stationary.
This was a common problem on early 205 GTI6 conversions - Check the ECU Pin to the VSS for continuity and maybe change the sensor.
Posted 15th Sep 2011 at 13:07
cwspellowe
Mate, you're a legend. Thinking about it, my VSS problems started around the same time as this happening. Cheers!
Posted 15th Sep 2011 at 19:43
cwspellowe
BUMP, tekkers?
Posted 17th Sep 2011 at 17:07
woody.
Will the TPS fit a 6 throttle body?
Posted 17th Sep 2011 at 18:32
cwspellowe
Yep, same throttle body, I have the VTS one fitted to my motor. YHPM by the way
Posted 17th Sep 2011 at 19:59
woody.
Dibs on the TPS mate?
Posted 17th Sep 2011 at 20:57
mike306
Did you get my text? Smile
High boost '6 for weekends
406 2.1 Executive for weekdays
Posted 3rd Dec 2011 at 20:35
wilyoldave
Inlet manifold badge please mate.
Paypal?
No more peugeots Sad
Snap - no more RS clioSad
Now Ph1 RS clio Smile
Posted 3rd Dec 2011 at 20:37
