Author Subject: Has My Hub Now Become Oval ?
beez_neez_gt
After the N/S ball joint went, at the time it had started to make a road noise. I found what seems to be a little wear on the inner side of the hub hole here >
However, the main inner depth part of the hub looks as it should. Although one picture does look like its ovaled Unsure
Its a 16mm hub not the 18 i was given via GSF Thumbs down
Pug fee`ver,
Pick a Bogey, buy a Pug.
Posted 12th Sep 2011 at 22:14
yeap thats gone Sad
Posted 12th Sep 2011 at 22:29
if you need a hub paul and i have some to mate
Posted 12th Sep 2011 at 22:30
beez_neez_gt
Cool, do you have one from your black 6 ?
Pug fee`ver,
Posted 12th Sep 2011 at 22:53
beez_neez_gt
Oh and tbh with you, the ball joint should have been spotted when i had the top mounts replaced at my local 6 garage a few months ago. The hub was bolted using an 8.8 rating not 10.9 like the OE Pug one's.
Pug fee`ver,
Posted 12th Sep 2011 at 23:32
yeah so has paul.......will have a good look at mine and make sure its all good
Posted 13th Sep 2011 at 08:49
yup, donald ducked, 8.8 bolt wouldnt concern me though as long as it was torqued up correctly.
of course if you were kerb hopping on 600 lb springs it'd be a different matter, but i'm guessing you arent LOL
Posted 13th Sep 2011 at 13:25
beez_neez_gt
No, my 6 is all original until i get hold of some VTS 21mm TB's Smile
But the torque originally applied is meant for 10.9 rating, the same torque on an 8.8 worries me. A garage should not go cheap on nuts and bolt IMO.
Cheers Greig, i think ill have a full set because you never know what the other side is like.
Pug fee`ver,
Posted 13th Sep 2011 at 13:39
