Author Subject: 306 maxi
gtisid
probably a repost but it is the first time i have seen it. looks like a genuine engine in the thing. must have cost an absolute packet to put this thing together:
french maxi
pugless
Phase 1 GTI 6 1996-1997
Subaru Impreza GB270 2007-2008
rare spiderman comics
same day international courier
Posted 11th Sep 2011 at 18:39
danposs86
Very nice engine! Cars not bad either.
danposs86's GTi-6
Posted 11th Sep 2011 at 18:46
dan_s16
Remembered why I stopped going to car shows now, that used to do my head in. Just sitting there revving the crap out of it.
It looks good but maybe it's just me but it doesn't sound right.
Posted 11th Sep 2011 at 18:57
roberts_306
Does not sound like a proper maxi to me
www.pugsport-racing.co.uk
Posted 11th Sep 2011 at 22:07
sounds like an adjustable rev limit?! certainly looks a good inlet setup, and youll never get a true sound by just revving with no load.
Posted 11th Sep 2011 at 22:21
gtisid
From what I have seen of maxis it is either a very accurate replica engine, or a genuine inlet set up. The brace looks genuine too. Probably the noise is from the twin pipe set up.certainly sounds like it is revving above 7k.as you would expect once a young French kid gets his hands on it they make it look shit.
pugless
Posted 12th Sep 2011 at 07:49
pete_rallye
Could well be a genuine inlet set-up, but I very much doubt a genuine Maxi engine. They were very very modified, well north of £25k's worth of modified...
Lap of the 'ring
Posted 12th Sep 2011 at 21:14
gtisid
possibly a replica, but that big gearstick in the cab looks like a sequential to me and that is the biggest chunk of cash on a maxi. All looks a bit real to me under the bonnet so maybe the guy bought a trashed maxi and fixed it up french stylee. still 30k plus worth
pugless
Posted 13th Sep 2011 at 15:31
pete_rallye
'Big stick' is a hydraulic handbrake. They have them easily in view so you're not fumbling trying to find it when required. Proper Maxi's had a 7 speed sequential. The engine doesn't sound anthing like a maxi, not anywhere near lumpy enough at lower revs. The cage is a bolt in job. Looks tidy but its not a 'real' maxi
Lap of the 'ring
Posted 13th Sep 2011 at 18:22
cwspellowe
Yes i spy an H pattern gear stick so it's either a sequential box with a factory gearstick or ot's not a maxi
Still, lovely looking engine
Bye bye Sundance Kid Sad
Posted 13th Sep 2011 at 18:32
Thats not a maxi there is other stuff under then bonnet on a maxi and that has not got it i'm sure the Maxi engine is dry sumped as well ? oh and a real maxi engine revs to 10k and sounds totally different as well - not a bad effort mind Yes
Posted 13th Sep 2011 at 19:15
cwspellowe
Sounds like a failry decent spec as it is, going off his other videos idle seems to be about 1500rpm which is usually a sign of a fairly lumpy cam, unless his bodies aren't balanced properly Laugh
Posted 13th Sep 2011 at 19:17
I'm sure mine was set to around 1200 if memory serves me correctly ? ran out of rpms at 8250 and oil Whistle
Posted 13th Sep 2011 at 19:23
gtisid
ok , now i have had a look again , you are right not a maxi. take the stupid stickers off though and change the lights and i would have it
pugless
Posted 13th Sep 2011 at 20:25
cwspellowe
Hydraulic lifters?
Posted 13th Sep 2011 at 20:28
You can see from the panels/paint/seats/belts/ride height, etc, that it's not a proper maxi.
Probably just a wide arch kit tarted up with a maxi engine intake.
Posted 13th Sep 2011 at 20:34
gtisid
inlet and bodies are worth more than the car you mean?
pugless
Posted 13th Sep 2011 at 20:37
cwspellowe wrote:
Hydraulic lifters?
Na the MI engine has a nasty way of spitting the oil out of just about every possible breather and the catch tank - they used to run them dry sumped so as to turn the oil into a controlled closed circuit - mine didn't have this so used to p*ss out everywhere - guess what happens if you forget to keep an eye on it No
Posted 13th Sep 2011 at 20:45
cwspellowe
Ahh didn't know it was on an Mi. Was reading Peter Taylor's website today about oil sumps on them, interesting stuff.
Posted 13th Sep 2011 at 22:15
most maxi's were based on the RFY head, only the very last of them used the RFS head casting.
Posted 13th Sep 2011 at 22:17
manthos
Is it a good idea to baffle the sump of a 6 if doing lots of track use? Can they suffer from oil starvasion in long corners otherwise??
Team SUPERCHARGED
Old Project thread
Posted 13th Sep 2011 at 22:28
roberts_306
I just knew it was not a Maxi sounds nothing like it, I went in a proper Maxi at Pugfest did not look like that piece of crap.
Why do french insist in reving the B*llocks off their cars when they arnt going anywhere
Posted 13th Sep 2011 at 22:34
Carl Chambers
GTi6 has a baffled sump as standard!
Carl Chambers
email; pugnacious.peugeot@yahoo.co.uk
C.M.CHAMBERS CARS
Peugeot Specialist
Tel; 01379 586101 after 6.30 or 07889 082466 anytime.
Posted 13th Sep 2011 at 22:56
Carl Chambers
no way is it a proper maxi, its has had a lot of money to make it look ok, but then why sit there and rev the crap out of it? pointless and does an engine no good what so ever to be reved hard with no load on it!
Carl Chambers
C.M.CHAMBERS CARS
Peugeot Specialist
Posted 13th Sep 2011 at 22:58
manthos
SWEET!! Wink
Team SUPERCHARGED
Old Project thread
Posted 13th Sep 2011 at 23:00
