Author Subject: Grind into reverse?
Had this on another GTi6 years ago and not sure if it's clutch issue or more.
Goes into gears fine, but when coming from say first to reverse off the clutch, it will grind initially. Take my foot off the clutch and depress it again and it goes in. It doesn't seem to like going into reverse only.
Reverse cable issue not selecting?
Unsure why it affects reverse only.
  • Posted 19th Aug 2011 at 01:57
    quite normal really LOL
    no synchro on reverse
    Posted 19th Aug 2011 at 02:25
    Thanks for the reasurrance that the thing is meant to be shite LOL
    It's just odd why it allows it in fine when the clutch is depressed quickly the second time round. Just when its held for a couple seconds while coming to a stop it doesn't like it.
    Ahh.. Maybe because it comes to a complete stop from in 1st the first time?
  • Posted 19th Aug 2011 at 02:29
    mattgti6phase2
    You will find if you are moving forward whilst selecting reverse then it will crunch.
    Stop being lazy and stop first Razz
    Team Nile 6 Superman
    Team: 40.2 MPG Smile
    5 x a 306 owner!
    I truely live for the 306 ®
    midweek madness Tee hee
    Posted 19th Aug 2011 at 04:34
    iplay
    Replace the reverse cable which stretches over time.
    Posted 4th Sep 2011 at 13:38
    dan86
    If the automatic adjuster isn't working or broken on the clutch cable, depressing the clutch pedal might not be fully moving the pressure plate away from the friction plate causing it to "drag". Consequently when idling with the clutch "in" the friction plate spins up the input shaft on the gearbox and when selecting reverse you try to mesh a moving cog with a stationary cog... Crunch. Try unclipping the clutch cable from the gearbox, push and pull the cable in and out from inside the engine bay to reset the cable and refit. Press the clutch pedal a few times.. it might adjust it to a new position curing your problem. If it doesn't try a new cable.
    Posted 5th Sep 2011 at 22:12
