Author Subject: Clutch Release Arm Pin
danposs86
Had the pin pop out of the clutch release arm on me last night. Lost the clutch but shoved a spare bolt I had in the car into its place and was able to get the car home.
Now this is the second time that it has happened. The one thats just gone was brand new from Peugeot and was always a bit loose.
I have ordered a new one (cost less than £3), however going to look into getting a similar size bolt or nut or a pin from a different car that also has a split pin to really hold it in place.
Does anyone know of any cars that might have a pin that can be properly fastened in?
danposs86's GTi-6
Posted 8th Aug 2011 at 22:39
theres meant to be a securing spring on there
Posted 8th Aug 2011 at 23:12
Need the spring thing in there as well to stop the pin coming out - check with pug as I'm sure they will be next to nothing Wink
Posted 8th Aug 2011 at 23:16
danposs86
The spring was on the pin, still was loose. Came with a cable tie as well when I got it from Peugeot, but never used it.
danposs86's GTi-6
Posted 9th Aug 2011 at 00:17
the pin in my experience tends to be a tight fit ?
bas**rd to get out
Never seen a loose fitting one ?
Posted 9th Aug 2011 at 00:31
danposs86
It was an arse to get on, but checked it once and it was half out. Forgot to check it in a while and it miust have some out all the way.
danposs86's GTi-6
Posted 9th Aug 2011 at 01:11
danposs86
Anyone?
Anyone know the diameter and length of the pin?
danposs86's GTi-6
Posted 9th Aug 2011 at 18:20
pin comes from pug with the spring. Sure you got the right one? Shouldnt come with a cable tie.
If a nut and bolt will do the job for you better then keep that. Its only to secure the fork.
  • Posted 10th Aug 2011 at 15:17
    peetypug
    What about using a split pin or a couple of the roll pins (like the ones on the door check strap)
    Cherry rallye - DOB Thursday 29/04/1999
    Team Rallye - the leaner, meaner, better looking sister of the GTI6 Big grin
    roland rat wrote:
    You sir either live for the 6 or have a mental retardation to still be repairing this!
    The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does its own oil change. It's just a pity the management system is so fecking temperamental.
    Posted 11th Aug 2011 at 04:44
    pug sell a differnt style one, i cant remember exactly but i think it has 4 small sticking out lines on it that make it tight as you have to knock it in and once that gets in it wont come out, ive bought 2 before and one was the standard one with spring and the other was tapered with a nut on the end to help removal. trouble with the teapered one was that i couldnt get it off and it had only been on for 2 months, maybe it was for a different car but it fitted and will not come out, pity i had to replace it with the spring type.
    andrew315rawson@live.co.uk
    Moonstone phase 7 gti6
    Posted 11th Aug 2011 at 14:22
    iplay
    I got one in my garage ... i'll take a look in a bit
    Posted 12th Aug 2011 at 17:29
    danposs86
    Got a new pin from Pug. It also came with a spring like the one thats just fallen out. Will see how it holds up.
    danposs86's GTi-6
    Posted 13th Aug 2011 at 00:08
