Author Subject: Emissions failed
peetypug
Took the gti6 for an mot today, failed it emissions
Fast idle test
Co 0.748 maximum should be 0.300
Lambda 1.259 maxim should be 1.030
2nd fast idle
Co 1.117
Lambda 1246
Natural idle test
Co 0.932 should be 0.500
Any idea what can be causing these readings?
Pete
Cherry rallye - DOB Thursday 29/04/1999
Team Rallye - the leaner, meaner, better looking sister of the GTI6 Big grin
roland rat wrote:
You sir either live for the 6 or have a mental retardation to still be repairing this!
The best engine in the world is the vagina, it takes any size piston, its self lubricating, starts with 1 finger, and every 4 weeks does its own oil change. It's just a pity the management system is so fecking temperamental.
Posted 8th Aug 2011 at 19:26
Coolant temperature sensor or the lambda is the usual suspect
Posted 8th Aug 2011 at 19:35
peetypug
Which one is the coolant sensor?
Posted 8th Aug 2011 at 19:46
green one
Posted 8th Aug 2011 at 19:48
peetypug
Cheers matey Big grin
Posted 8th Aug 2011 at 19:54
lewisdmz
Take it for a good blast before hand, especially if you've been pootling around in the city.
Posted 8th Aug 2011 at 20:06
aggyj17
mine were roughly the same readings bottle of petrol magic+a good thrashing = pass
Posted 8th Aug 2011 at 20:33
colgti6
if the car only failed on emissions get a dodgy mot
Adding up the bills for the 6
Posted 8th Aug 2011 at 22:22
mad scientist
It didn't only fail on emissions though, did it Peety!
205 rally car with 2.2 hybrid 6 engine: phase 2 engine build underway.
Posted 9th Aug 2011 at 02:12
peetypug
No, but everything else is easily fixable
Will sort the other issues, take it for a thrash take it to test the emissions. If it fails I'll try the. Coolant sensor if that fails I'll try the lambda
Posted 9th Aug 2011 at 05:04
peetypug
Well it passed it's emissions
I swapped the coolant temp sensor as a precaution, couldn't get the lambda off though! Somebody has tried before and rounded it off, so I think they struggled last time.
The tester (different one to before) asked if it had had a belt recently, I said yes then he bounced it off the limiter a few times, that bought the co and lambda right down!
Posted 12th Aug 2011 at 12:07
